Old member
OK here is what I got.
I have a 94 Elderado touring coupe that our son wrecked a month ago. It's a salvaged title car so it's not worth the $2500-3000 to fix it. It would be worth maybe $1500.00 so! I was thinking of buying this truck for I hope around $1000.00 and put all the caddy stuff in it. Motor, trans, gas tank everything and yes make it front wheel drive. Put all the interior everything I can in the truck. The truck has no running gear at all in it. Clean the truck up and get it it running and drive it. I know it will take a lot of work but it's just time then it can be done when I can get to it. ![]()
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
Re: Pondering
Errr, no. It's front wheel drive- just......no. Lol
'72 Chevrolet Step Side 350/TH350, '63 C10 Step V8 '74 Trans Am 400, '80 Trans Am Indy Pace Car Mercedes AMG S55, SLK230 Kompressor, GL450 '96 Dodge Indy Ram Official Indy Truck '99 Porsche 911 Carrera |
CAN'T FIX NOTHIN
Re: Pondering
No on the fwd
1967 C10 Shortbed Fleetside Small back glass 6 cyl 3spd on the tree 3.08 gears underdash AC |
Re: Pondering
Do it just to say you did it.
Re: Pondering
I hope you can buy that truck for less than a grand
Posted via Mobile Device |
Old member
I haven't called him yet but I think I can also. I know making it FWD isn't the best way and if I could find a way to put the motor in it with a regular trans I would think hard about doing that instead. I sure hate the caddy just sitting out back. Anybody know of adapter to do this.
laying low
![]() Join Date: Mar 2001
Re: Pondering
It would sure be different Andy. I think that's a 4.6 Lt engine. The swap would most likely be easier if you cut the caddy frame at the firewall and splice it into the truck frame. That way all your mounts are already there, suspension and all. It could make for a nice cruiser.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
Petroleum User
Re: Pondering
First off, anything that gets the truck out of the field is good. Is the eldorado worth anything? Id try to sell it and do something more relative to the truck. But, as I said, whatever gets it out of the field...good luck
![]() 1971 GMC Sierra Grande 2WD 1/2 ton, 350/400 auto 2008 Chevy Silverado 2WD 1/2 ton LT1 5.3L auto |
Re: Pondering
If I had such ability.....
Go for it man! Although it would be much easier (read "faster") to put in the regular 6 cylinder, rwd set up, not to mention much, much cheaper. Especially if you could sell the wrecked car and then the money saved could perhaps fix up the truck a bit. But hey, it's your stuff man and it's a super interesting idea. Keep us posted with lots of pics! |
Re: Pondering
Since it's a new idea I would splice the frame in and then all front end with no guess work at all. Just think at a car show with the hood up and there she is a Caddy under the hood. Like nike said "Just do It"
Re: Pondering
Andy, funny you post this. I was just thinking about the possibility of front wheel drive in one of our trucks. Am liking the suggestion of prior post of grafting the caddy front end to the truck frame.
Was good to meet u in bham on power tour. Who knows, maybe u can run power tour next year on this truck. Posted via Mobile Device
![]() Join Date: Jun 2012
Re: Pondering
Put a 5.3 in it and drive it how it sits....I dig it
United States Marine Corps 2000-2011 Iraq and Afghanistan veteran Just living life now and enjoying it and my wife, daughter and son ![]() |
#13 |
Old member
The whole point of this is to get something out of the wrecked Caddy. The car already had a salvaged title before it was wrecked so now if i sell it as is it's worth about $500.00 whole. If I take everything out of it and put into the truck I can have a truck to drive and have a one of a kind front wheel drive.
Needless to say something to talk about at shows. ![]() ![]()
#14 |
Re: Pondering
It would be a LOT of work...but would be pretty cool if done right.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() Last edited by slow-1; 08-05-2013 at 07:39 AM. |
#15 |
I am a Referee of life.
Re: Pondering
Might work better with a frame swap.Could be pretty low though.and the frame would need to be stretched.Still a cool idea and would turn some heads and some noses up.I think this type of innovative thinking is what got the hobby started.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#16 |
Re: Pondering
If memory serves me right, that Caddy basically has a Chevy 350. The 4.6 Northstar didn't show up until the later 90's. If that's correct, I just simply wouldn't do it.
Here's why. First off, you want to put this in a truck. Trucks already have an unbiased weight balance(heavier up front). The Caddy is engineered for this weight balance in the car chassis and platform. When you install this into a truck with the entire drivetrain into the front, it's going to be too nose heavy, and in all reality, will probably not drive well at all. I believe that understeer, which fwd cars are notorious for, will be greatly increased in a truck platform and become an issue at even low speeds. I don't think it's a bad idea just because I don't like fwd vehicles, but because I don't think it will be a safe vehicle to drive when completed.
#17 |
2WD Jimmy
![]() Join Date: Mar 2005
Re: Pondering
No
#18 |
Re: Pondering
I saw a flatbed truck at the Daytona Turkey Rod Run last year with an Eldorado powertrain in it.
I agree that it would be cool, but I also think you would be opening a huge can or worms. You've got to be one heck of a fabricator to make that work.
71 Chevy C10 Shortbed Stepside. LT1 with 4l60E. Just got back from painter, in assembly now. |
#19 |
Old member
94 Elderado has the northstar 4.9 in it. I'm no where near doing this yet just thinking out loud about what to do with a perfectly good running motor and trans but the car isn't worth fixing.
#20 |
Re: Pondering
The 4.9 was not a Northstar. It is a bored and stroked HT4.1 V8
![]() In fact the whole idea is ![]()
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#21 |
Old member
I stand corrected on the motor but weather it is are isn't doesn't matter, the fact is it's free with just my labor which is also free if I decide to do it.
This is what google says it is. 4.6L V8 DOHC 32V FI Engine I know it gets 24 miles to a gallon and that would be nice in a 72 truck. It want get that good I'm sure but I bet it will get better than most carb trucks of the same year. ![]() ![]()
#22 |
![]() Join Date: Jul 2013
Re: Pondering
It's a Sacrilege! A blasphamy
![]() But, it is your truck! What ever you decide to do, enjoy it and keep us posted
Mark Jesus is the Way! 2003 2500HD CCLB Duramax/Ali (Clifford) 2014 2SS/RS black on black Camaro (Betty) 2006 Pontiac SOLSTICE silver/black (Lula-Bell) 1970 C/10 Short Wide (Peggy) 1964 C/10 Short Step (Hambone) RIP Jimmy Hamilton Thank you for the trucks |
#23 |
Re: Pondering
That sounds like a simple, inexpensive project that will be very quick and fun to complete.
Josh '70 Custom Camper / 20 |
#24 |
![]() Join Date: May 2002
Re: Pondering
you could always install the engine in the bed, and make the front a trunk.
you know, a mid-engine, rear-wheel drive truck.
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD ![]() Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
#25 |
Re: Pondering
Way to much fabrication, in my opinion. Especially if you haven't done anything like this before. I think it would cost a lot more too. If you want a front wheel drive pickup, just buy a 4wd and remove the rear drive shaft.
![]() Seriously, I'd sell the Caddy for whatever you can get. It may not be much, but maybe enough to buy a wrecked car or pickup with a drivetrain that would bolt into the pickup. |
