Old 08-04-2013, 05:53 PM   #1
suspect
suspect's Avatar
What proportioning valve do I need?
72 c10, swb, 383/700r4, front wilwood d54 12" diam X 1 1/4" rotors, rear wilwood d154 12" diam X 1" rotors, front lines 1/4", rear lines 3/16"
This is the booster I have on order.....http://www.classicperform.com/Store/...ck/6062BB9.htm
I have the Wilwood master cylinder 1 1/8" bore.....http://www.summitracing.com/parts/wil-260-8556
I don't necessarily have to have a wilwood prop valve, but these are the 2 I'm eyeing right now.
This one has 3 outlets. Do I just plug off one hole? http://www.summitracing.com/parts/wil-260-11179
This one is single in/out. Am I able to plump straight off the master cylinder and go right into the front brakes? Then plumb this prop valve just for the rear brakes? http://www.summitracing.com/parts/wi...0922/overview/
I kind of like the single in/out one. What's the best way for me to set my brakes up? I'm open to other suggestions also. Thanks, Daniel
Daniel
68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594
Romans 10:13 Everyone who calls on the name of the Lord will be saved.
suspect is offline   Reply With Quote
Old 08-04-2013, 06:05 PM   #2
jocko
jocko's Avatar
Re: What proportioning valve do I need?
I'd be tempted to day you need a dual inlet/dual outlet prop valve (as in the factory setup), however, I'm not as up to speed on high perf braking systems as I'd like to think I am In your case, since you have a Wilwood Master Cyl and a disk/disk combo (pretty darn nice setup you have there) - I'd go to the trouble of calling Willwood's Tech line and ask the following (I am of the mind that brake lines should be the same diameter for front/rear on a disk/disk setup - but maybe Wilwood can confirm):
I have a Wilwood MC part # umptifratz and front/rear disk brakes...
- is this the right MC for a disk/disk setup (I think it is correct)
- can you please recommend the correct prop valve for this
- and, I am currently running the factory disk/drum sized lines (i.e. 1/4 and 3/16), should I run all the same diameter lines, and which diameter (1/4 or 3/16) for this particular MC/disk/disk combination?
Wilwood:
Phone: (805) 388-1188
Fax: (805) 388-4938
Email: customerreply@wilwood.com
Hours: 7:30am - 5:00pm PST Monday - Friday
Old 08-04-2013, 06:30 PM   #3
67 chevelle
67 chevelle's Avatar
I would run a disc/disc combo valve , if your back brakes lock first on a dirt road [ I seriously doubt they will ] then and only then would I put a proportion valve in
67 chevelle is offline   Reply With Quote
Old 08-04-2013, 07:07 PM   #4
screaminchevypickup
Laid Back
screaminchevypickup's Avatar
You really don't even have to have a prop valve with that master but if you want I would just run a adjustable one on the rear line..
72 chevy swb
Direct dealers for..
Vintage Air, Porterbuilt, Billet Specialties,Budnik wheels ,eddie motorsports, raceline wheels, intro wheels, Dakota Digital, precision, unisteer, Trimparts, and many many more... Laid Back Recreations.. Full restoration shop and full paint and body..
Kyle
http://67-72chevytrucks.com/vboard/s...d.php?t=574629
screaminchevypickup is offline   Reply With Quote
Old 08-04-2013, 11:06 PM   #5
suspect
suspect's Avatar
I suppose I'll go ahead and try it out without a prop valve. Add one later if it isn't working out.
Daniel
