Old 08-04-2013, 11:28 PM   #1
aggieguy713
aggieguy713's Avatar
Running light issues..:thud:
Hey fellas,
I have a 70 chevy step side, and about a month ago I started having issues with my driver side running light in the grill. Was standing in front of it one day, and noticed the light was out, happened to push on the lens a little and it came on, but when the pressure was taken off it still was out. So I figured it was the bulb, even though it still would blink. Replaced the bulb, nothing, checked all the grounds, nothing. I traced the wires all the way to the inside of the cab and nothing is broken. My turn signal indicator on the driver side stays on constantly when the lights are on, not sure if this is related or not? Thanks in advance for the help.
70 Chevy C10, LT1, T5, "Blue Beast"
aggieguy713 is offline   Reply With Quote
Old 08-04-2013, 11:36 PM   #2
Cape Codder
Cape Codder's Avatar
Re: Running light issues..:thud:
If you remove the bulb does the turn signal indicator do off? I suspect you have a bad socket on the light. Remove the bulb and push on the wires from the back to inspect the spring. It needs to hold the contacts against the bulb.
Cape Codder is offline   Reply With Quote
