Old 08-04-2013, 11:47 PM   #1
epon
epon's Avatar
Largest Wheels and Lowest Drop Without Frame Mods on 82' SWB?
I think I've seen a 22" rear with 5.25" offset and 20" with 4.25" and a 6/7 static drop but I cant find the thread. Hoping someone can tell me the lowest static drop and largest staggered wheel/tire sizes with offset I can go with an 82' SWB.
Also wondering if an auto trans can be easily swapped from an 81 swb to a 82 swb with a manual trans.
TIA!
epon is offline   Reply With Quote
Old 08-05-2013, 11:05 PM   #2
slammed427
slammed427's Avatar
Re: Largest Wheels and Lowest Drop Without Frame Mods on 82' SWB?
I've got a 5/7 drop on my 74 with 20's all the way around. I have more than enough room for 22's in the back, with a decent tire.
If you get the driveshaft from the 81, it's a fairly simple swap. Add an external trans cooler, change your flywheel to a flex plate, etc.
74 C10 LWB 350/T5 Dropped on 20's
Soon to be Bagged and Injected
84 C35 Crew Cab Dually. 454/400 Dropped a lot.
Instagram: mmmdropp
slammed427 is offline   Reply With Quote
