08-05-2013, 10:08 AM | #1 |
Rusty Nuts
16" 6 lug Yeah!
Finally found a set of 16" 6 lug they came with the tires, were they worth a 100 dollars. I thought so, they are hard to find.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
08-05-2013, 12:58 PM | #2 |
Re: 16" 6 lug Yeah!
Love my 16s
Figure out what you want--then figure out what you are willing to give up to get it. |
08-05-2013, 01:47 PM | #3 |
Re: 16" 6 lug Yeah!
Nice find! Do you happen to know the width?
1967 Chevy C-10, 250 L6, Powerglide, 3.73, SWB, Fleetside Upgrades: Power steering, Offset air cleaner, Rear Sport bumper, 3 point safety belts, HEI, -1/-2 springs, 16x5 wheels, McGaughy's disc brake conversion, Sway bar |
08-05-2013, 01:49 PM | #4 |
Re: 16" 6 lug Yeah!
08-05-2013, 02:11 PM | #5 |
Re: 16" 6 lug Yeah!
235/85R16s on the front and 7.50/16s on the rear
08-05-2013, 02:24 PM | #6 |
Re: 16" 6 lug Yeah!
Hey Lou, I've got a set of these too, are your wheels 5" wide as well?
1972 Cheyenne Super 10 SWB,bucket seats,dealer cruise,tilt,tac,a/c,shoulder belts, 350/350 1971 K-10 Custom Deluxe 1971 K-10 Custom |
08-05-2013, 02:52 PM | #7 |
Re: 16" 6 lug Yeah!
not sure of the rim width. 5" seems narrow. Is there a way to tell from the tire size?
08-05-2013, 03:36 PM | #8 |
Re: 16" 6 lug Yeah!
It's possible to come up with a pretty accurate measurement with the tires on. I've been on a wheel quest for a while, so I've spent a lot of time measuring them with tires on. In any case, if you really want to do it, this works:
A. Place a flat edge all of the way across the front of the tire and the back of the tire. Measure the distance between. B. Measure the distance from the outer lip of the rim to the flat edge resting against the tire on both front and back. C. Add the 2 measurements from B together and add 1 inch. A - C = rim width This has always worked for me when measuring stock steel wheels. Posted via Mobile Device
08-05-2013, 04:08 PM | #9 |
Re: 16" 6 lug Yeah!
5" on the money. Why didnt I think of that
08-05-2013, 04:40 PM | #10 |
Re: 16" 6 lug Yeah!
You did measure to the outer most lip (where rubber meets metal) of the rim, correct? I wonder if all of this style are 5"?
08-05-2013, 06:19 PM | #11 |
Re: 16" 6 lug Yeah!
Yup, I did.
08-05-2013, 06:25 PM | #12 |
Re: 16" 6 lug Yeah!
I really like the look of your truck. The wheel and tire combo look perfect. I'm impressed as to how nicely the 235's look on a 5" wheel. I've been looking for a set of 16's for a while now, but haven't found any yet.
08-05-2013, 06:34 PM | #13 |
Re: 16" 6 lug Yeah!
there are so many great stances for these trucks. The only real solution is to buy more trucks! I wanted a tougher, ranch stance on mine as that's its heritage. I left to "mudder" 7.50's on the rear. Also, the 16's help fill up the side mounted well better than a 15" Only limit for us is our imagination.
08-05-2013, 07:04 PM | #14 |
Re: 16" 6 lug Yeah!
Nice find Mr. Chevrolet! Those rims will look great on your truck. Always like to see the progress on your build. Your doing a great job on it.
CHEVY/GMC VIN DECODERS |
08-05-2013, 07:44 PM | #15 |
Rusty Nuts
Re: 16" 6 lug Yeah!
Yes they are 6" wide. I think from what I measured
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 Last edited by Mr Chevorlet; 08-05-2013 at 07:53 PM. |
08-05-2013, 07:49 PM | #16 |
Rusty Nuts
Re: 16" 6 lug Yeah!
Thanks bruceman I 'll post some picks of the bed and a couple of pieces of wood installed. Got the fender wells all worked out and painted.
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 Last edited by Mr Chevorlet; 08-06-2013 at 09:08 AM. |
08-05-2013, 08:44 PM | #17 |
Re: 16" 6 lug Yeah!
those look great, and nice find.
anyone know what year/models those particular wheels were offered on? Not exactly common... also, curious if they fit over a disk brake upgrade - being 6 lug, they were clearly for pre-71 half ton trucks, so wondering if the extra 1" diameter helped make up for the taper on the backside of the pre-71 rims where the caliper/wheel interference normally occurs during a disk upgrade? |
08-05-2013, 08:55 PM | #18 | |
Re: 16" 6 lug Yeah!
http://67-72chevytrucks.com/vboard/s...d.php?t=350240 I pm'd back and forth with a member that said they clear discs with no issues.
08-05-2013, 09:11 PM | #19 | |
Re: 16" 6 lug Yeah!
08-05-2013, 09:17 PM | #20 | |
Re: 16" 6 lug Yeah!
08-05-2013, 09:31 PM | #21 |
Re: 16" 6 lug Yeah!
thx guys - good info. still confused as to whether or not they clear disks... will follow along. Just a note - am pretty sure the 71-80ish 4x4 6 luggers are 15" - and, yes, they clear disks (if those are the ones you're talkin about factorystock - OR, was there ALSO a 16" 6 lug K10 wheel available I'm not familiar with?)
Thanks again for the great info and link. |
08-05-2013, 10:28 PM | #22 |
Rusty Nuts
Re: 16" 6 lug Yeah!
The ones I just bought and posted came off a 1984 Chevy 4x4 and they will clear the disk brake calibers.
08-05-2013, 10:35 PM | #23 | |
Re: 16" 6 lug Yeah!
08-06-2013, 07:18 AM | #24 |
Re: 16" 6 lug Yeah!
I can't tell from the picture. Are there 3 or 4 nubs/bumps or on your wheels for hubcaps? If there are 3, they will all be the same size. If there are 4, there will be 2 bigger ones and 2 smaller ones.
08-06-2013, 09:12 AM | #25 |
Rusty Nuts
Re: 16" 6 lug Yeah!
NC67 there are only three nubs on these.
