Old 08-05-2013, 11:01 AM   #1
Cruzinlow
Cruzinlow's Avatar
Head Light Switch
This is my first post of many to come I started to disassemble my dash on the 65 c10 this weekend and couldn't figures how to remove the knob on the headlight switch. I'm thinking it should just pull off but I gave it a tug and it wouldn't budge and I didn't want to force it. So is there a trick to getting these off?? On a side note I have a inline 292 3 three speed trans with over drive can anyone tell me what it's worth???
V.
1960 C10 SWB
BBW
Restoration in Progress
Cruzinlow is offline   Reply With Quote
Old 08-05-2013, 11:14 AM   #2
1963c-10
1963c-10's Avatar
Re: Head Light Switch
If you look under the dash at the side of the headlight switch, you will see a little button that is spring loaded. Push this in and the knob will slide out from the front. Remove the bezel to the switch, and the switch will drop out from the back.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-05-2013, 05:23 PM   #3
mater63
mater63's Avatar
when you put the switch back put in a headlight relay to the take the amperage off the switch. you lights will be brighter & more reliable
mater63 is offline   Reply With Quote
Old 08-06-2013, 12:06 PM   #4
kieth
kieth's Avatar
V.
the od 3 speed is worth some money hang on to it......the 292 is a good engine also, sell them both together.....trans 300.00 engine ?
kieth is offline   Reply With Quote
