Old 08-05-2013, 01:39 PM   #1
757chevy
Tail Light Problem
Hello all, I've got a 1966 pickup and currently trying to get my lights all squared away, my brake lights work, my rear signals work, but my rear running lights wont work I'm pretty sure I've got everything hooked up right any ideas? thanks!
757chevy is offline   Reply With Quote
Old 08-05-2013, 01:52 PM   #2
1963c-10
1963c-10's Avatar
Re: Tail Light Problem
Do your front park lights work when the switch is pulled into the 1st position? If you know the wiring is correct, I'd check bulbs 1st, double check all connections and then the switch. The wiring for the tail lights is pretty straight forward. Does your license plate light come on also?
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-05-2013, 02:16 PM   #3
757chevy
Yes both front parking lights are working in the 1st position, and i checked both bulbs and both filaments are working. At the bulb socket with the the switch in the off position both wires are ground with switch in the 2nd position both wires are hot. Idunno if that helps at all, i checked all connections and everything seems right.
Old 08-05-2013, 02:21 PM   #4
1963c-10
1963c-10's Avatar
Everything sounds correct. If its both taillights, I'm inclined to think its the switch. Especially if the bulbs are good, and the wiring is good. I can look tonight...I think I have 1-2 spares laying around that came from various parts trucks over the years. I lived in Newport news, Hampton and va. beach from 2000-2006. I really miss the friends and area, but have grown to being back in NC. Welcome to the forum also.
Old 08-05-2013, 02:30 PM   #5
757chevy
I'm actually mistaken in the off position my left light at both wires is ground but i also have a 3rd mystery wire hanging from it ( i bought the truck not too long ago still fixing PO's stuff) and at the right light one wire is ground the other is nothing... in the 2nd position on the left both wires are hot and on the right one one wire is hot the other is still nothing.
Old 08-05-2013, 02:35 PM   #6
1963c-10
1963c-10's Avatar
See if this helps any
Old 08-05-2013, 02:37 PM   #7
1963c-10
1963c-10's Avatar
The site is working on some things, so this is the best I can do size wise unless you PM me an email and I can send it in a larger scale. From left to right you have tail light, reverse light, license plate light, reverse light and tail light. You can also save the image and enlarge it.
Old 08-05-2013, 02:59 PM   #8
757chevy
ok that helped a little, new dilemma though NOW the running lights work, when i left signal its uses the running light filament to signal instead of the bright and when i signal right it uses the bright filament but my left light turns off, also when i hit the brakes my right light works using the bright filament but the left turns off!
Old 08-05-2013, 03:26 PM   #9
jtrichard
check grounding
jtrichard is offline   Reply With Quote
Old 08-05-2013, 03:35 PM   #10
1963c-10
1963c-10's Avatar
Originally Posted by jtrichard View Post
check grounding
x2
Old 08-05-2013, 04:12 PM   #11
757chevy
ok ill check, thanks!
Old 08-05-2013, 04:38 PM   #12
1963c-10
1963c-10's Avatar
You cannot ground enough on these trucks. If you ground the entire lighting system better you will notice a difference. Quite a noticeable difference when I grounded the dash lights also.
Old 08-05-2013, 04:59 PM   #13
757chevy
It was some bad grounding cuz of some paint, thanks for the help!!
