3.73 and posi
I have a 12 bolt posi that I will not be using. I was told it was rebuilt with stronger springs when I bought it. It has 3.73 gears with it (cant remeber which series that makes it). Looking to get what I paid for it $375 with gears $350 with out.
![]() Join Date: Nov 2012
Re: 3.73 and posi
What brand name and are the ring and pinion new?
My 69 cst lwb 2wd LS1 swap 5.7/4L60e build http://67-72chevytrucks.com/vboard/s...d.php?t=589869 |
Re: 3.73 and posi
Guess that would help it is all stock gm parts. I'm open to offers. It is just taking up room on the shelf.
Posted via Mobile Device |
Re: 3.73 and posi
Ok, I'm looking for a new one
Thanks anyway Posted via Mobile Device
![]() Join Date: Aug 2008
Re: 3.73 and posi
Interested. Any documentation of rebuild and/or photos? Shipping cost to Cedar Park Tx 78613
Re: 3.73 and posi
Are you sure it's for a truck and not a car 12 bolt?
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
Re: 3.73 and posi
I do not have any documentation of the rebuild, only the mans word that it had been done. I am almost certain it is for a truck but if you can tell me the difference Ill double check.
Re: 3.73 and posi
Re: 3.73 and posi
Does the posi carrier have the window like you took the photo of the springs through on one side or both? What is the diameter of the pinion shaft? What is rhe nber stamped on the carrier housing? How many splines are on the axle housing? These details will tell if its for a car or truck.
Re: 3.73 and posi
There are 2 windows and the casting number is ed30060 which is for a series 4 truck carrier.
Re: 3.73 and posi
$350 shipped
Re: 3.73 and posi
Ttt
#13 |
Re: 3.73 and posi
ttt need it gone
#14 |
Re: 3.73 and posi
$325 shipped final price drop
#15 |
Re: 3.73 and posi
Will a 4 series carrier fit in a there series housing.
#16 |
Re: 3.73 and posi
Yes any will fit. They are just for different ratio ranges.
#17 |
Re: 3.73 and posi
Looks like 41 teeth on the ring and 10 teeth on the pinion. Wouldn't that make it a 4:10 ratio?
#18 |
Re: 3.73 and posi
PM Sent
#19 |
Re: 3.73 and posi
There are 11 teeth on the pinion making it 3.727....
#20 |
Re: 3.73 and posi
PM Sent
#21 |
Re: 3.73 and posi
sold
