08-06-2013, 11:25 AM | #1 |
383 375HP 400+ Tourque ...What trans?
Buying a 383 like the header says at the end of the year, 69 C10 Stepside,the truck is old so most mechanical/moving parts are getting replaced. Cutting corners on cheap **** usually bites me in the ass, so we're not trying to go that route.
1. I live in SD, lots of highways, T56 overdrive ???? Pass on the 4L80E's.... 2. Reinforce the frame? 3. Rear end is 3.73, who makes a reliable fresh kit to replace the old? 4. Its going to be DD/ and a frequent autocross contestant at Qualcom!!! 5. Anyone who has done something similar, let me get your input. Thanks in advance. J
http://http://67-72chevytrucks.com/v...d.php?t=578181 |
08-06-2013, 01:46 PM | #2 |
2WD Jimmy
Re: 383 375HP 400+ Tourque ...What trans?
08-06-2013, 03:04 PM | #3 |
I'm definitely going MT when I restore my truck. Until then it's good ol' TH350.
08-06-2013, 05:18 PM | #4 |
TCI streetfighter is a bad azz tranny. Mine has held up to many years of 3200 rpm launches at the track with 456 posi rear on mt street slicks.
Hi everyone, It's nice to know there's other people just as crazy about these old trucks as I am. oldno7 |
08-06-2013, 09:10 PM | #5 | |
I recently bought a 700R4 built to handle 750 HP / 700 ft-lb from these guys: http://www.transmissioncenter.net/ so far so good. |
08-06-2013, 10:15 PM | #6 |
X2. 700r4. It will give you that launch off the line and in the auto cross, then an overdrive to compensate on the freeway and for the 3:73.
I'd stall it about 2800 rpm (don't know your cam/intake specs) Posted via Mobile Device
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
08-06-2013, 10:19 PM | #7 |
2WD Jimmy
J[/QUOTE] He needs the manual tranny for this IMHO . Posted via Mobile Device |
08-06-2013, 10:29 PM | #8 |
Roto Reuter thats the name...
Considered going with a 200-4R from Hughes Performance, but mine isn't a daily driver so right now I can't really justify the cost. I'll stick with the TH350. Nice swap though with 200-4R. No driveshaft modification. Drop it right in. Maybe change to trans mount position. Also, according to them there is no problems with TV set up due to their internal design. Would have to research it again as it's been a while.
http://www.hughesperformance.com/ind...d=57&Itemid=59
~ Dan My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
08-07-2013, 12:07 AM | #9 |
motor exploder
The TREMEC TKO (500 or 600) is a proven performer. The T56 is in the same boat. Thousands of them on the road & track. I've run a TKO500 in two different trucks, one a small block, one a big block, both with 3.73's.
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
08-07-2013, 12:14 AM | #10 |
Call Dana Sniff racing transmissions, in irvine/
1 man shop..he does all the work himself. 949-559-6563 did my trans, works very well. good honest guy.
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
08-07-2013, 03:11 AM | #11 |
Judging by all the views, I suspect most were looking for some truck porn HAHA sorry no pics of the engine yet. Those of you with responses thank you for them. YES 100% a manual tranny!!! TKO 500,600,or the T56 are all monsters.
Thanks Jay
