Old 08-06-2013, 01:21 PM   #1
robber grin
Proportioning Valve on 62 C10
Would anyone be willing to share where and how you mounted the proportioning valve on your truck after brake upgrade?
I need to figure this out and get mine bolted down to finish the lines.
Thanks - bob
robber grin is offline   Reply With Quote
Old 08-06-2013, 01:33 PM   #2
1963c-10
1963c-10's Avatar
Re: Proportioning Valve on 62 C10
Mine has a mount that goes to the master cylinder and holds it in place.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-06-2013, 01:52 PM   #3
notsolo
notsolo's Avatar
I did this about 20 yr ago( on My 62) changed the whole front end over to an 83... brake booster in normal location and proportion valve.... I put down low in front of the 83 cross member. all parts came from the 83.. ( that may have been stock location don't remember ) I am having trouble resizing photo's if you want I can email them to you...Ed
notsolo is offline   Reply With Quote
Old 08-06-2013, 02:09 PM   #4
markeb01
Senior Enthusiast
markeb01's Avatar
I also did mine on the crossmember. 1960 chassis, 1975 front suspension, proportioning valve on the rear of the crossmember below the motor mount to keep the area around the booster free of clutter:
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 08-06-2013, 02:32 PM   #5
robber grin
Thanks guys - I'll try to snap some pics of what we come up with - leaning towards Mark's approach at this point.
Thanks again - bob
Old 08-07-2013, 09:28 AM   #6
kieth
kieth's Avatar
Thanks - bob
We used the front crossmember off a 91 burb, used the proportioning valve from that vehicle and the brake lines. The valve is located on the front of the radiator support bracket. Kieth
http://kieth.smugmug.com/Trucks/66-G...0261&k=ksmb3c8
kieth is offline   Reply With Quote
Old 08-07-2013, 10:17 AM   #7
slepysal
slepysal's Avatar
That is a nice set up were did you get it ?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
