Project Heaven in my 67!!!
Square Diesel 4X4 Burb Mileage???
I am looking at a 4X4 burb with the diesel. What kind of mileage can I expect to get on a factory setup? Are there any upgrades that make it get better mileage?
Re: Square Diesel 4X4 Burb Mileage???
Should get 18-22,maybe 24 mpg,if it's got overdrive. A couple few less without that,unless you drive slower. But,at least 18.
Second Chance Program
6.2? Pretty much all stock? Then i would echo what special said.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt. 77 C20 crew cab Silverado. 396/th400. In work. |
18-22 stock 16-24 with a banks turbo setup.
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd |
Slots go on anything!
You can have the injection pump tuned as well, either for mileage or power. We had an '83 when I was a kid that had the pump worked, and it would click off 22 all day long with a TH400, 31's and 3.42 gears. I loved that truck.
1974 Jimmy- 5.3/4L80e/NP241 |
And if I convert it to 2WD???
2wd may get a couple better MPG. These motors are all about torque,so not many factors detract from the mileage. They don't work harder till you add a lot of drag/weight. My '91 3/4t 4wd had 4.10s,4L80E,and 12.50/35-16 mud tires on 10" steel wheels and got 22mpg with 1000# of tools/cargo
i do not think it makes any difference 2wd or 4wd i've owned both no noticeable differences.
I know the pieces fit
Even with 4x4 they're good on fuel. They take a square from thirsty beast to pretty economical as far as full sized trucks go, even against the new stuff.
Yep,they're the classic 4wd that makes sense for today...better than many new trucks...even with big tires!!
