![]() Join Date: Sep 2012
Dual exhaust
Turned out in front of wheels?
Turned out behind wheels? Straight back under bumper? PO cut the exhaust pipe at the last hangers. It looks like they used to turn out behind the back wheels. My neighbor owns and exhaust shop. He said he would hook me up. Just need to decide on how I want to route them? |
![]() Join Date: Dec 2012
Re: Dual exhaust
1968 Chevrolet C/10 LWB - 327, TH350 - 4/5 Drop |
Re: Dual exhaust
They are nice straight out the back. Lmc has a new rear bumper that has cutouts for dual exhaust makes it look good.
Posted via Mobile Device |
Re: Dual exhaust
I've got an 80's step bumper on the back of mine. I was leaning towards taking them out the back but with no chrome tips and was thinking I would have them stop just under bumper and not protrude past bumper. I was also thinking I would have them a little wider than what OregonNed's are. Not all the way out to quarters....but a little wider.
I was also thinking about putting my spare back underneath my bed.... |
Re: Dual exhaust
I'm a big fan of you your tail pipes are done, my daily driver is pretty much the same, pipes hidden underneath and just the last 1/2" of a turn down tip showing, nice and clean and next to nothing of a rusty pipe or rusty chrome tip showing, lets face it chrome tips and new exhaust pipe look good new but 2-5 years later there an eye sore.
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
I have a radical idea!
Re: Dual exhaust
Turning them out in front of the rear wheels will create a lot of cab noise, and dumping them under the truck befor axle usually creates a lot of drone at highway speeds. I am a fan of going straight out the rear, or at the minimum turned out after the axle (although I'm not a huge fan of that look).
I had flowmasters on my '69, and it wasn't bad at all in the cab. ![]()
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
Re: Dual exhaust
I concur with Swamp Rat about the chrome tips looking ragged after a few years. Don't know if I like the slight turn down tip or just straight pipe tip. Hmmm |
Re: Dual exhaust
mine are turned out behind the rear wheels and i like the look...not the greatest picture for reference..only ones ive got for now...
http://s1063.photobucket.com/user/Bi...tml?sort=6&o=4 http://s1063.photobucket.com/user/Bi...tml?sort=6&o=3 Last edited by Drewski23; 08-07-2013 at 01:09 AM. |
#9 | |
Moderator
![]() Join Date: May 2007
Re: Dual exhaust
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Re: Dual exhaust
im going to leave mine out back for the look but add the cut outs for the noise..
Re: Dual exhaust
i've got flowmasters and quite a bit of lobe so the exhaust is pretty throaty. it looks like the exhaust used to turn out behind the rear wheels and the PO just cut it right at the hangers. since this is a fee.99 hook up.....i think i'm just going to ask him to make new hangers, route the pipes around spare and go straight out right under the bumper and just cut the pipes straight, even with the back of the bumper. no tips just the pipe.
Re: Dual exhaust
I like straight out the back as well.
Although I saw one the other day with stainless pipes bent at 45 degrees or so comming out behind the rear wheel and the end cut at 45 degrees to be flush with the side of the truck...looked pretty nice. Posted via Mobile Device
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives ![]() |
#13 |
Re: Dual exhaust
side exit behind the wheels
Figure out what you want--then figure out what you are willing to give up to get it. |
#14 | |
![]() Quote:
![]() ??, to turn out behind wheels: tires will kick up road tar and mud on them ![]() YES, to straight out back--even w/bumper, just past bumper, just before bumper w/ends bent down slightly. IMO, one of these 'outbacks' would look the best all around. ![]() Sam |
#15 |
Re: Dual exhaust
Straight out the back is out of style, turn them down behind the bumper.
I'm not as good as I once was, But I'm as good once as I ever was. |
#16 |
Re: Dual exhaust
#17 |
Re: Dual exhaust
mine come out in front of the rear tires. I think it would be ok if I was 16 or if I had an X pipe to kill the slight rattley sound of the turbo mufflers. I wish I had gone out the back or gotten better mufflers and an X pipe
#18 |
Re: Dual exhaust
I have true duals from headers back with Flowmaster mufflers. No H or X pipe or anything. It looks like the PO just took a hacksaw to the pipe just behind the hangers. I assume the tail pipes used to turn out under quarter panels behind the rear wheels and the PO didn't like the look so hacked them off.
I think I'm going to have tail pipes welded on with new hangers and take it straight out the back, no tips, no turn downs...just straight tail pipes stopping even with the back of the bumper. Should I have them put a cross pipe in to make an H upstream of the mufflers???? |
#19 |
Re: Dual exhaust
I'm re-doing mine like this (see my diagram) and with these basic components starting with block hugger headers so I can still get great ground clearance while running dual 3" exhaust.
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
#20 |
Re: Dual exhaust
I don't have a photo but the pipes exit behind the rear wheels, but are turned down and tucked up under the bed so you can't see them.
Mike, I didn't know you were so style conscience. ![]()
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#21 |
Re: Dual exhaust
No white shoes after Labor Day, and no exhaust out the back.
#22 |
Re: Dual exhaust
#23 | |
Cluster King
![]() Join Date: Nov 2012
Re: Dual exhaust
#24 |
![]() Join Date: Feb 2001
Re: Dual exhaust
A husband can be right...or...A husband can be happy. ![]() 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. ![]() 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc ![]() ![]() JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
