Old 08-07-2013, 08:24 AM   #1
mgeez
mgeez's Avatar
Rear Suspension '51 - 3/4 ton
Is the upper set of rear springs called an "auxilliary spring set"? I am trying to figure out if this upper set of springs is part of what makes the rear suspension a 3/4 ton truck. Do 1/2 tons have this upper set? I will never load anything other than a cooler in the bed and was wondering if i would get into any problems removing this upper set. Some advantages I might have would be 1) a more "clean" look in that area, 2) a softer ride, and 3) it may lower the rear a bit. If I can remove the upper set, I figure i will need new U-bolts since there appears to not be enuf threads on the bolt itself if i remove the upper set. Any help would be appreciated.
Mgeez
Felton, Pa.
My toys: 1951 Chevy Truck 3600, 1952 Chevy Truck 3800, 1954 Case 411B, 1939 Ford 9n, 1972 Kubota B7100
http://s1282.photobucket.com/user/m_geesey/library/
mgeez is offline   Reply With Quote
Old 08-07-2013, 08:49 AM   #2
Katrina/10
Katrina/10's Avatar
Re: Rear Suspension '51 - 3/4 ton
No, the half tons do not have those springs. They do not affect the ride unless they are touching the brackets on the frame.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
