K5 C Notch
I'm wanting to install a flip kit on the rear and try to go as low as I came and keep the factory floor. From what I've found so far no one makes a C Notch for the Blazer frame. Has anyone found one?
Re: K5 C Notch
I have this one book marked:
http://www.airbagit.com/1973-1991-CH...fli-che-04.htm It is ambiguous in that is also says C10/20, but they also list different kits for C10's? http://www.airbagit.com/category-s/2242.htm
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
Re: K5 C Notch
Have you bought the one that list that it fits the blazer?
Re: K5 C Notch
No, bookmarked for later reference.
Re: K5 C Notch
Just bought a c notch from CPP. I have modified the whole thing to fit. Better off to make your own.
Posted via Mobile Device |
Slots go on anything!
Re: K5 C Notch
The biggest problem you will have is with the pumpkin hitting the rear floor. That will hit long before the axle tubes pose a problem.
1974 Jimmy- 5.3/4L80e/NP241 |
Re: K5 C Notch
When I measured last night I had 7in from the pumpkin to the floor but only 4in until axle tube hits the frame I dont think I measured incorrectly but maybe
Re: K5 C Notch
is that hitting the frame or the bump stop bracket and bump stop?
1991 Chevy suburban 3/4 ton 4x 4:56 and pulls great 1979 Chevy 1/2 ton long bed diesel 1974 Chevy crew cab short bed 3/4 ton 4x4 project 1991 Chevy suburban 2wd 1984 Chevy suburban 3/4 ton 4x 6.5 detroit with turbo 1961 Chevy pickup 1/2 ton 2wd 1975 gmc crew cab short bed 2wd |
Re: K5 C Notch
The bracket where the bumpstop mounts
its just $$$$$
Re: K5 C Notch
I usually do a 2.5" notch if keeping the stock floor.
Low & Fast!
Re: K5 C Notch
here is what I did. Easy to do and at big as you can go if you have a 12 built.
#13 |
Re: K5 C Notch
Tvblazer did you box in the frame on the inside? What is the flat plate arch that is welded on the frame for?
#14 |
Low & Fast!
Re: K5 C Notch
No I did not box it in and the plate is my old bag mounts, i just left them on for now.
