08-07-2013, 03:46 PM | #1 |
Anyone ever connect a 7 pin connecter to their truck?
I'm looking to install a 7 pin connector in my truck but not sure where to start. I have a hitch but not sure where to start on the wiring. Should I just wire it from the fuse box or what?
Thanks in advance. Posted via Mobile Device
1969 Chevy c20(Miss Hackjob) |
08-07-2013, 04:00 PM | #2 |
Re: Anyone ever connect a 7 pin connecter to their truck?
All depends on what you want to tow they make a nice adapter the plug into the rear harness and chassis harness. It has three wires both turn wires and stop wire also ground. If you are using electric brakes you run a single 10/12 gauge blue wire from controller to 7 way socket. The other wires are 12v from key (to charge brake away battery or interoir lighting) and back up lights. Hope this helps I have put many trailer sockets on.
08-07-2013, 04:09 PM | #3 | |
Proprietor of Dale's Corner
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
08-07-2013, 05:00 PM | #4 |
Thanks guys this does help! Where would I find these harnesses? I'm debating doing a trailer brake set up but not sure.
08-07-2013, 05:10 PM | #5 |
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
08-07-2013, 05:16 PM | #6 | ||
08-07-2013, 05:38 PM | #7 | |
http://www.hopkinstowingsolutions.co...ban_73-84.html http://www.hopkinstowingsolutions.co...ring_codes.pdf |
08-07-2013, 05:38 PM | #8 |
Hey we have a trailer shop too that's a good idea I might have to stop down there.
