Where should I connect the engine hoist?
So I've looked around a lot and cannot seem to find a good solution to this question. Trying to be as careful as possible, I'm sure you all understand. So I'm looking to hoist out my 350 sbc from my 1972 c10. Transmission is staying in the truck. Where should I connect the hooks for the hoist? Should I use two corners or four? Should I even use corners or should I do it another way? Thanks in advance!
![]() Join Date: Dec 2012
Re: Where should I connect the engine hoist?
I use a chain bolted to opposite intake manifold corners. I'm sure some will say there are safer ways to do it. I have just used this method on V8s with IRON heads for 35+ years with no adverse results. Make sure your chain is sturdy enough and you use good quality bolts and washers.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
Proprietor of Dale's Corner
![]() Join Date: Nov 2012
look at what I posted in your other thread
"Some Days Chickens And Some Days Feathers" Dale XNGH ECV Sam Brannan 1004 R.I.P. 67ChevyRedneck R.I.P. Grumpy Old Man |
#4 | |
If the engine is stock it might still have the lift tabs still attached, it's usually one in the rear on the intake and one in the front on the other side.Attach a piece of chain to these two tabs, then place your engine hoist hook in the middle of this chain. Take it easy, you may have to adjust the hook a little as you see how it lifts!
What I like to use is a plate that mounts to the intake with the carburator off.
