Old 08-07-2013, 03:52 PM   #1
Anti-Ricer
2 questions relating to 65 Chevy truck. Ps bracket & blinker or lack of
Where is a good place to buy a power steering conversion kit for a 65 chevy truck with a 04 350 vortec.im going to buy the power steering pump at my local parts store(Oreillys) I just need the bracket and all the hoses and bolts.I seen one made by a member on one of these forums that was like 58 dollars for the bracket.
My next question is about blinkers or turn signals as some call the.My 65 has a late 70s-80s chevy steering column but doesnt have the level for blinkers on it.So unless the blinkers switch is located somewhere else on the truck im S.O.L. I haven't really looked anywhere else nor do I begin to know where to start looking for them or trying to figure out how to fix them.I'm on a mad dash to get this truck running so I can take it to a big rolling 2 day hotrod/muscle car/ratrod/you name it car show September the 16th in pigeon forge TN.
Anti-Ricer is offline   Reply With Quote
Old 08-07-2013, 05:11 PM   #2
billd5string
billd5string's Avatar
Re: 2 questions relating to 65 Chevy truck. Ps bracket & blinker or lack of
For the turn signals, if you don't want to fix the switch that is in the existing column, you could get an external switch like this one from speedway motors. I know other suppliers like LMC truck have them also.
The link is:
http://www.speedwaymotors.com/Heavy-...tch,30566.html
65 C20 Fleetside longbed, 350, turbo 400, 8-lug disc brakes, power steering, air conditioning - Totaled by a guy running a red light. Pulling parts off the carcass for my next truck
billd5string is offline   Reply With Quote
Old 08-07-2013, 06:34 PM   #3
Bigdock
Can't help with any of the problems but I'm on a mad dash too to get my new to me 64 gmc ready for rod run might see you around
Bigdock is offline   Reply With Quote
Old 08-07-2013, 07:30 PM   #4
Anti-Ricer
Sept 13th is the deadline.ill keep a eye open for you
Old 08-07-2013, 11:36 PM   #5
MARTYZ
MARTYZ's Avatar
Captain Fabs (forum member)bracket will get your steering box mounted in about an hour with a drill and welder, I used it with great success. My guess on the signal issue is the lever is broke off, cant think of GM column without signal switch from 70s or 80s, remove steering wheel and replace switch lever, I would go to local wreckers and get hoses and switch lever from V8 pick up. Just my thoughts, Good luck!
MARTYZ is offline   Reply With Quote
Old 08-08-2013, 12:37 AM   #6
slepysal
slepysal's Avatar
Not to hijack but how do you wire the rear lights with that universal kit?
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 08-08-2013, 12:47 AM   #7
Captainfab
60-66 Nut
I would be the member that sells the power steering box adapter plate. There is a link to the for sale thread in my signature line \/ \/ \/ \/
Send me a Pm or an email if you are interested.
Old 08-08-2013, 08:47 AM   #8
Anti-Ricer
Im seen that blinker switch before on some other 60-66 I have owned.I remember looking bat it and thinking so this is how they done blinkers back then.it was mounted to the steering column with a metal strap. little did I know that these trucks never had blinkers from factory.ill try to fine some pics of that truck to post them up. it was a two tone gun metal blue and silver fleet side with a 327. that truck would do burnouts like no othrr
Old 08-08-2013, 10:25 AM   #9
1963c-10
1963c-10's Avatar
Anti-Ricer....these trucks did have blinkers from the factory. The were built into the columns. The bolt on column blinker was designed for trucks that were made prior w/o blinkers or for those who broke the blinkers and did not fix them with the proper parts.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 08-08-2013, 10:29 AM   #10
Anti-Ricer
thanks for clearing that up.What years never had them tgrb?
Old 08-08-2013, 11:39 AM   #11
1963c-10
1963c-10's Avatar
I'm not 100% sure on that. I do know that 60-66 had them in both chevy & GMC. I have a buddy who is big into the 48-59 models. I will ask him.
Quick search online shows left/right harness back to late 55 when the model changed.
Old 08-08-2013, 12:07 PM   #12
61K10
61K10's Avatar
i think in 55-59 they were an extra. i had a 58 chevy custom cab f/s and it had no turn signals. installed one like in the pic. this was back in 64/65. later i had a 57 and it had turn signals.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 08-08-2013, 04:39 PM   #13
66Submarine
66Submarine's Avatar
I think they were technically an option until '63 or something?
66Submarine is offline   Reply With Quote
Old 08-09-2013, 11:38 AM   #14
cab_01
cab_01's Avatar
So I need one of these for the 78 power steering box to mount to my 65? I haven't pulled it from the 78 yet but it looked like a direct bolt on. I may be wrong about that, but please explain what this bracket does?
cab_01 is offline   Reply With Quote
Old 08-09-2013, 12:35 PM   #15
66Submarine
It spaces it out, and also reinforces the frame so you don't tear it up. If you look at the 78 frame, you'll notice it has raised mounting points where the box bolts to it. (Also the 78 PS box will have an additional fourth mounting bolt.)
Old 08-09-2013, 12:47 PM   #16
cab_01
cab_01's Avatar
Cool thank you.
Old 08-09-2013, 12:49 PM   #17
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Turn signal were still an accessory / option in 1960 or so I`ve seen kits for.
Old 08-10-2013, 12:32 AM   #18
Captainfab
60-66 Nut
The adapter plate not only locates all 4 holes for you, with the supplied template, but it also spaces the box outward to compensate for the lack of an indent on the '67 and earlier frames.
