Old 08-07-2013, 03:52 PM   #1
IntegratedTJ
IntegratedTJ's Avatar
One more question about pulling the engine.
Been looking around about this, too, and haven't really been able to find out if I'd need to detach the torque converter from the flex plate to remove the engine/detach it from the transmission. Anyone know? 1972 c10 350 sbc
IntegratedTJ is offline   Reply With Quote
Old 08-07-2013, 03:58 PM   #2
MARKDTN
Re: One more question about pulling the engine.
ABSOLUTELY! If you don't you will have a real mess. Also, you must have the converter off the engine to get it to realign with the pump.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 08-07-2013, 03:59 PM   #3
IntegratedTJ
Thanks for the quick reply. Sorry, I'm new to this
Old 08-07-2013, 04:05 PM   #4
Longhorn 70
Longhorn 70's Avatar
after you unbolt it, slide your hand in between the flex plate and converter. Push the converter back toward the trans as far as you can...may be 3/4" or so.
While the engine is out you may also want to instpect the converter snout and replace the seal on the pump.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 08-07-2013, 04:08 PM   #5
IntegratedTJ
Thank you both very much. Appreciate the responses.
Old 08-07-2013, 04:14 PM   #6
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
I live in Fairfield and work in Benicia, If you need me to I can come by and give advice and show you. it would be easier to understand what people are telling you if you can have it pointed out in person
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 08-07-2013, 04:18 PM   #7
IntegratedTJ
I appreciate it a lot, but I think I've got it now. I'll definitely let you know if I'm in need, though. Aha. Thanks a lot!
Old 08-07-2013, 04:21 PM   #8
Ol Blue K20
No problem just don't hesitate to ask, I'll be glad to help ya out
Dale
Old 08-07-2013, 04:26 PM   #9
IntegratedTJ
Appreciate it very much. I'll make sure to hit you up if we're stumped.
Old 08-07-2013, 04:27 PM   #10
truckster
truckster's Avatar
One more thing...
If you happen to slide the convertor out, be careful putting it back in. It needs to be rotated to seat on the pump drive. If you just force it, you'll break the pump, and then you're replacing the trans.
truckster is offline   Reply With Quote
Old 08-07-2013, 09:00 PM   #11
mikeshome
mikeshome's Avatar
You will have to turn the engine to get out the last torque convertor bolt,not sure if 3 or 4 on this model but torque will spin free when you have them all out.
mikeshome is offline   Reply With Quote
Old 08-08-2013, 04:25 PM   #12
IntegratedTJ
Got the torque converter disconnected successfully and it was a smooth engine pull! Thanks a lot for all of the advice!
Old 08-08-2013, 04:28 PM   #13
Ol Blue K20
Congrats!!!
Dale
