Old 07-03-2003, 06:07 PM   #1
76bonanza
76bonanza's Avatar
ticking sound
When driving with my window down I have a ticking sound gets faster and slower with wheel rotation. So I think it is for sure the wheel area. When I lighly apply the brakes it stops? Anyone have any idea?
1968 c10
lowered 3" 4"
355/Th400 built by Hatfield racing in joplin MO
76bonanza is offline   Reply With Quote
Old 07-03-2003, 06:21 PM   #2
sbc350gearhead
sbc350gearhead's Avatar
U-joint or cv joint(front wheel drive...yeah yeah, I know I shouldn't mention FWD stuff but you didn't specify, so no verbal abuse please......LOL).
sbc350gearhead is offline   Reply With Quote
Old 07-03-2003, 06:24 PM   #3
87 STEPPER
STILL PLAYS WITH TRUX
87 STEPPER's Avatar
Arrow
First thing i would do is jack up the front end and tighten both wheel's and then do the same for the rear especially if you have any kind of aluminum rim's.
Then drive the truck and see if the sound is gone.
If not then look at your front brake's.
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
87 STEPPER is offline   Reply With Quote
Old 07-03-2003, 06:26 PM   #4
76bonanza
76bonanza's Avatar
it is on my 4x4 so you think it is from the front drive shat cv joint?
1968 c10
lowered 3" 4"
Old 07-03-2003, 06:29 PM   #5
87 STEPPER
87 STEPPER's Avatar
NO! NO! YOU STUPID DUMMY! YOU KNOW HE'S TALKIN' ABOUT A TRUCK WHY ELSE WOULD HE POST HERE? J/K
~~Bruce~~
MY 87 STEPPER
MY 99 2D/WD TAHOE
Old 07-03-2003, 06:30 PM   #6
sbc350gearhead
I know absolutely nothing about 4x4's. If your truck has cv joints then it is possible. The same sound came from my camry when the cv joints went bad, and the bad sound came from my truck when the u-joint went bad.
Old 07-03-2003, 07:53 PM   #7
76bonanza
76bonanza's Avatar
How can you tell if the ujoints are shot? And also if I pull the speedo gear out of the transfer case to check it will fuild leak out?
1968 c10
lowered 3" 4"
Old 07-04-2003, 12:07 AM   #8
iufan71
U-joint problem
My first vehicle was a 76 Chevy 2wd(tan and white two-tone). I had the u-joints replaced in it,till then everytime i put it into drive,there was a big clunk noise. After replaceing the u-joints,the noise disappeared.
iufan71 is offline   Reply With Quote
Old 07-04-2003, 01:03 AM   #9
pissonNOS
senior member
pissonNOS's Avatar
i would simply close the window or turn up the AC/DC
69 GMC bagged
pissonNOS is offline   Reply With Quote
Old 07-04-2003, 01:25 AM   #10
sbc350gearhead
Hop under your truck and wiggle the driveshaft. If you see, feel or hear any slop, your u-joints might be going out.
Old 07-04-2003, 11:13 AM   #11
hrc200x
Could it be a rock behind a beauty ring/ hub cap?
'75 Chevy 3/4 4x4, 6" suspension lift, 3" body lift, 3" lifted gas tanks, '83 cab, '88 clip, 35" cooper tires, American Racing Baja rims, 350, 700r4, 208.
hrc200x is offline   Reply With Quote
Old 07-05-2003, 04:02 AM   #12
Chevy_68
Chevy_68's Avatar
thats weird cause mine does the same thing i'll check it out and tell you what it is
Chevy_68 is offline   Reply With Quote
Old 07-05-2003, 04:03 AM   #13
Chevy_68
Chevy_68's Avatar
oh by the way its going in the shop so what they tell me i'll tell u
Old 07-05-2003, 06:36 PM   #14
navybear70
hometown heroes!
navybear70's Avatar
Wiggling the driveshaft alone won't tell you. You should grab each joint and look for play at the source. My driveshaft is 100% tight. No gear play or anything, but I'm pretty sure my joints are going bad, cause I'm getting the clunk and the squeaky squeal too. Mine is bad enough that it does it under load, and now when I'm coasting too.
2009 Silverado 2wd, 121k as of 04APR13. I love my truck 29 days out of the month. The payment is due on the 30th...
Do your duty in all things. You cannot do more, you should never wish to do less. -Robert E. Lee
"Never give up ground you've already taken." -Unknown
navybear70 is offline   Reply With Quote
Old 07-06-2003, 09:33 AM   #15
Capitol68
Capitol68's Avatar
ah this did this to the x's car, drove me nuts.
ended up jacking up the one side tire and spinning it without tire.ended up being the brake pad riding the high spots on rotor, each time it hit low spot it would fall and click, took a screw driver and hammer and tapped the little ear on pad to tighten it up a liitle to caliper. fixed it
'68 Fleet LWB
orig 307 .030 over
GM Hei/w Accel Super coil
orig. stock TH 400.
_______________________
“What we do for ourselves dies with us. What we do for others and the world remains and is immortal.”
Albert Pine
English author d.1851
Capitol68 is offline   Reply With Quote
Old 07-06-2003, 11:30 AM   #16
SCOTI
SCOTI's Avatar
I had this same problem w/my 74 & thought it might be the front wheel bearings since the noise is continous. I replaced the bearings when rebuilding the front end & greased them properly, but I noticed the noise again last night when driving so I'm still trying to figure it out.
The brake pads on the caliper is worth checking. My 68 would make a loud clicking noise, but only when leaving from a stop. When I investigated the noise, I noticed a gap on the 'fingers' that hold the pads securely in place. A couple of quick taps w/the hammer to limit pad movement & that fixed the prob.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 07-06-2003, 12:44 PM   #17
boataddict26
My friends F*** Ran*** was making a ticking sound the other day when it was in forward or reverse. We were going down the road at about 65 and there was a guy behind us that was waving and making a comotion. (The 33in tires on this truck are shot and vibrate the truck so bad and make so much noise you cant think!!) Any way, when we turned of the main road onto a county road we stoped to take a look, what we found was the rear left wheel was about to fall off!! All the lugs were just held on by a few threds!! My idiot friend let his little cousin tighten it!! The rim is shoot!! So like 87 STEPPER said, CHECK YOUR LUGS!!
1978 Chevy C10 Currently under resto.
350 Getting face lift. .060, JEpistons, Modify heads. More will come with money.
boataddict26 is offline   Reply With Quote
Old 07-06-2003, 04:50 PM   #18
apstguy
LED King
apstguy's Avatar
This is a little off topic, but every time I let off the brake pedal, one of the calipers squeak. It has been doing this since I got it. Doesn't mean something is going bad does it?
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
