Old 08-08-2013, 01:13 AM   #1
nitrosport_5
nitrosport_5's Avatar
Center Cpnsole Mounting bolt size
I am converting my truck over to factory buckets and am wondering what size bolt the center console uses to mount to the cab floor. Is it 5/16-18 like the seat tracks? and is there supposed to be a welded square nut on the underside of the cab?
Thanks!
"Rusty" 1972 K20 Cheyenne Super, 496, A/C, Tilt, Tach, Buckets, 4l80e/NP205, 4" Rancho Lift, 35" BFG AT
"Ramp Truck" 1972 C30 Ramp Truck 350, Air Bags, Factory A/C.
"1968" C10 Shortbed project
nitrosport_5 is offline   Reply With Quote
Old 08-08-2013, 01:21 AM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Center Cpnsole Mounting bolt size
They are hex head sheet metal screws with washers very similar, if not identical, to the screws that fasten the fan shroud to the top radiator brackets. No reinforcement of any kind under the floor. Just screwed to the floor pan.
FirstOwner69 is offline   Reply With Quote
