Old 08-08-2013, 04:26 PM   #1
Aljohnsonii
what size wheel spacer to use
i have a 1968 gmc half ton and i want to put a set of late model rims on it i know the back spacing isnt the same what i would like to know is what size spacer can i buy to install the late model rims
Aljohnsonii is offline   Reply With Quote
Old 08-08-2013, 06:18 PM   #2
lolife99
67-72 parts collector,…
lolife99's Avatar
Re: what size wheel spacer to use
It would really help to know the backspacing of the late model wheels.
Keith
Convert to disc brakes.
Old 08-08-2013, 06:27 PM   #3
Aljohnsonii
i couldnt find the specs for the factory rims i just bought 1 1/2'' spacers and going to try them i seen on here where a guy use 98 and used the 1 1/2'' spacer and it worked
Old 08-09-2013, 09:30 AM   #4
Custom 68
Custom 68's Avatar
Don't forget suspension changes like disk brakes will change tour front track width.
Dave
1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap
1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?)
"A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome".
"If it doesn't fit force it...If it breaks then it needed to be replaced anyway!"
Custom 68 is offline   Reply With Quote
Old 04-13-2014, 06:16 AM   #5
Aljohnsonii
I used the 1" 1/2 wheel spacers and I'm able to put stock rims on from 00-2013 model gm trucks
