![]() Join Date: Oct 2011
67 C20 split rim/hub cap question
will dog dish caps (67 C20) mount on ANY other wheels? or split rims only?
thanks guys!
Dave "... government even in its best state is but a necessary evil. Thomas Paine "It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men) |
Re: 67 C20 split rim/hub cap question
my searches turn up WAY to much info....so I haven't found anything.
somebody must have a thread on this?
Rusty Nuts
Yes they will as long as you get wheels with three or four nubs on them for the hubcap to press on
(Clever Missouri) Southwest Larry Mr Chevrolet My Build, The Marathon Truck http://67-72chevytrucks.com/vboard/s...d.php?t=604414 |
They'll fit any pre-69 GM 8-lug single wheel in any diameter and any type of bead. Any earlier hubcap will also fit through '67. I don't think there were ant 16" clinchers made till the outer nubs were in use...post-72
cool, thanks! I was told they only fit 16.5" split rims and I found a few photos but can't see the wheel type very well.
i'm not sure I am going to buy the caps yet (a wee bit pricey) but the chrome ones are getting few and far between.
Actually,16.5s were clinchers and 16s were split rim. I've never seen 16.5 split rims
This question comes up often. Most people want to run 16" one piece wheels on C 20's. Problem is GM never manufactured 16" one piece wheels with necessary wheel clips. GM did manufacture 16" 2 piece rims with necessary wheels clips, but most people don't want to use 2 piece rims. So, owners of 20 years worth of 3/4 tons and 1 tons (1948 thru 1968) are forced to run hard to find one piece wheeel tire sizes if they want to run original hubcaps on these vehicles. All these 16.5. 17.5 and 19.5 one piece wheels with clips are hard to find. Installing old clips off these rims and installing them on modern 16" wheels is also a possibility. I personally am looking at some late model Ford Econoline 16' wheels( 2006 and up only). Believe it or not, these wheels have no typical bumps on them, they are designed for full wheel covers only. THey may be the perfect candidate for adding clips.
Aren't those later Econoline wheels metric lug pattern? I believe the clips are sold and someone could take on the painstaking task of properly locating them. I'm thinking the other issue would be the early clip style hubcaps are 10 1/2",just like 1/2t,and that may present another issue. i'm thinking maybe there are aftermarket wheels made in 16" with clips.It seems to me I've run across those before.
The Niner
![]() Join Date: Nov 2010
The Econoline van wheels have luckily stayed with the 8 x 6.5 bolt pattern this whole time.
"A good racer is one whose head is in communication with his balls." - Richie Evans 1970 C/20 - 402/TH400/3.54s - 74K miles 2003 GMC Sierra 2500 - Wheatland Yellow Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183 Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/ |
Ok,I've only dealt with the hubcap style and those went metric. Those must be pickups-only after '96 and that's when Vans went to wheelcovers(?). I wouldn't know. We're talking Ford here
#11 | |
I'm thinking I did see ones that are made now. I wish I had more info. You're right,someone should make the stock replacements. Makes too much sense,although Wheel Vintiques did finally catch on to making "most" OEM-type wheels. Even with custom wheels,it seems when a nice looking wheel comes out they discontinue it to put out 5 more that are just plain dumb looking. I guess they figure the market is just plane dumb,and probably right,cuz they are being bought.
#13 |
#14 |
those Ferd wheels look good...can the clips be bought? or do they have to be scrounged up at a wrecking yard?
#15 |
#16 |
I did a search on car-part.com for 2007 ford van wheels with pics and they have the bumps...probably a generic foto though.
the search came up with wheels as old as '93 also
#17 |
You guys sound like you know more about wheels than I do. I have wide rear wheels and stock fronts in 16.5 2 piece split rims. If I'm understanding your posts correctly there is no such thing as a 16.5 1 piece skinny stock wheel? I would like to run the caps that I have on the truck. I have 4 16.5 8 lug with lock rings off another truck but I don't want to run lock rings. I'm assuming that no one out there is going to want to buy those right? Everyone is looking for the 1 piece right?
1969 K20 not running, complete but rusty with wrecker boom and push bumper 1969 GMC C20 un-molested rust free original paint "a 4 eyed girl named 'Tina" 1971 Chev K20 4X4 Box Delete Commercial Truck Flatbed "Choose a job you love, and you will never have to work a day in your life." Confucius |
#18 | |
I don't know much about wheels...but many here do. someone will chime in.
#19 | |
I believe Brothers sells the hubcap clips?
#20 |
Six in a row makes it go...
![]() Join Date: Mar 2009
I saved the clips from my split wheels and plan to put them on newer wheels some day.
67 C20 long step resto: http://67-72chevytrucks.com/vboard/s...d.php?t=342086 66 C10 long step build: http://67-72chevytrucks.com/vboard/s...=1#post3814790 CT to Alaska in a 67 C10: http://67-72chevytrucks.com/vboard/s...d.php?t=399224 “The height of sophistication is simplicity." - Clare Boothe Luce |
#21 |
Brothers carries the clips for 47-63....but I don't think that would make any difference to the hub cap. LOL
#22 |
![]() Join Date: Feb 2011
Please make like a build thread on this. I'm wanting to do the same thing.
I'm sorry I called you stupid. I thought you knew already. 67 C-20 Custom Camper 68 Nova 396 it does wheelies 2005 Buick Century the one the wife drives 1989 Toyota Tercel to drive when I can't put gas in the first 2. Last edited by Daddy Brim; 08-13-2013 at 07:48 AM. |
#23 |
I knew I shouldn't have hauled those split rims to the dump. guess I'll order the clips from Brothers.
#24 | |||
I posted a pic of one of the 69 lock ring rims I have and 2 pics of the single wheel that I threw in the bed 8 years ago. It is a 16.5 1 piece and I added another pic of the stamp that's on it. I hope this is the right wheel, if anyone can chime in that would be helpful. Thanks
#25 | |
