Old 08-09-2013, 09:02 AM   #1
bigmac73
bigmac73's Avatar
Question question about brakes
I am converting my 72 C-10 to power brakes, Summit racing recommends that i use
http://www.summitracing.com/parts/CLP-6772BB2-11/
and they say this is all i need for the conversion,
Is there any type of other extension rod i need to find for the pedal??? Any thoughts??
Mike
bigmac73 is offline   Reply With Quote
Old 08-09-2013, 10:09 AM   #2
68gmsee
Active Member
68gmsee's Avatar
Re: question about brakes
I'm not recommended one vendor over an other but mine looked like this. http://www.brotherstrucks.com/prodin...number=KORN772
I would check on the vendor site for local vendors. Also, I would give them a call and ask questions. A lot of them have everything you need and some have done the work themselves.
68 GMC 250/3 speed Saginaw p/b p/s
69 Chevy 350/350 currently in pieces still lookin for a cab
06 Trailblazer
I just want a vehicle that I can work on, that won't talk to me, leave error msgs or keep track of how I drive...
68gmsee is offline   Reply With Quote
Old 08-09-2013, 10:25 AM   #3
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Your 72 C10 doesn't have power brakes from the factory?
I got a Booster and Master cylinder with proportioning valve from CPP to replace my 40 year old worn out unit. Works like a charm.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-09-2013, 01:15 PM   #4
bigmac73
bigmac73's Avatar
Nope it is an odd model, power steering but no power brakes??? Go figure
anyways i was going to go with the CPP from summit, i just was wondering if i am going to have to go hunting a odd ball part or something, like a different pedal rod or something small like that
Old 08-09-2013, 07:20 PM   #5
68gmsee
Active Member
68gmsee's Avatar
I'm not familiar with the one you're looking at but you will need the brake pedal to booster bracket link. As I mentioned, if you call some of the vendors, some of them can fix you up with what you need. Be sure and readjust the brake light switch if you have to.
06 Trailblazer
