08-09-2013, 03:25 PM | #1 |
help i got the oringinal 327 and intake i need help
i just got the truck and was so excited about it i just took a quick look at intake when i got the truck the man said carb was in truck and it was so got the truck home picked up carb and top fell off the ooold small 4 barrel rochester and found out no floats or anything in it the ports are smaller than holley and cant find adapter for anyone else have this problem dont want to change intakes
08-09-2013, 03:34 PM | #2 |
Re: help i got the oringinal 327 and intake i need help
I may be wrong but i believe that a Rochester quadrajet was standard in 67. Prior to this was a Rochester 4gc. Sounds like yours is missing parts (?) if just the float is missing they are abailable and should be replaced when rebuilding anyway. A quadrajet should be easy to source. It depends on if the carb you have is original and if you want to retain it for numbers matching issues. If it is, you could probably find a donor carb for parts. If not concerned with that issue, any Sbc q jet from the early to mid 70's would work with little to no modifications.
Posted via Mobile Device |
08-09-2013, 03:35 PM | #3 |
Post a photo of the carb and give us the numbers on the left side running vertically toward the rear of the carb.
08-09-2013, 04:28 PM | #4 |
Probably a 4GC. I would buy an aftermarket aluminum or factory Qjet intake and a later Qjet. You will be way ahead moneywise as those 4GCs are getting harder to find parts for and do not offer the performance/mileage of a Quadrajet. With a 67 you will either have to find an early stock or aftermarket intake with the oil fill hole or go to later valve covers.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
08-09-2013, 04:52 PM | #5 |
heres the intake on it the carbs few miles away i was being stupid and got another updated carb a holley thinking it would bolt up to the intake come to find out it wouldn't the diameter of the ports are larger
08-09-2013, 05:01 PM | #6 |
ya its the 4gc and i would need a complete carb to fix it cause theres no flosts no vacuum secondary no spring or anything its just a shell basically if lol but he did give me a rebuild kit with it
08-09-2013, 05:07 PM | #7 |
X2 aftermarket aluminum intake. Many of these allow a Q-jet [spread bore] or a Holley, AFB, Edlebrock performer, [square bore] carb. This gives you many options and the ability to change your mind and carbs as you wish. I understand not wanting to change manifolds but you really will be miles ahead in the long run. Nice looking 67 you have there! Have fun making this YOUR truck.
08-10-2013, 06:35 PM | #8 |
found the adapter online for it ordered it and it came in of course it came missing bolt that bolt it to in take so can't put on till tue or wed. it sucks
08-10-2013, 07:06 PM | #9 |
if anyone else have this problem and don't want to change intakes heres pic of adapter and part number[ATTACH][ATTACH][/ATTACH][/ATTACH]
08-11-2013, 10:14 PM | #10 | |
...and seems you are quite nice to have not bad-mouthed the p/o from whom you received a carb-shell--quite respectable of you!!! Sam |
08-11-2013, 11:31 PM | #11 | |
72 Cheyenne super 10 08 3500 HD 4dr dually 12 ford flex (wifes ride) 76 Monte Carlo 83 Chevy short wide Silverado 96 Mazda Miata, 2000 Allegro Bus |
08-12-2013, 12:52 AM | #12 |
ya its the adapter i can use for know so i can at lease drive truck see the rochester that came on this is the 4gc it has the same bolt pattern as the qua-jet [can't spell] but the ports are smaller than holley in diameter i didn't want to change intakes to put an holley on it so found the adapter so i could use the holley for right know till i can find a parts rochester so i can put stock one back on
