08-09-2013, 04:20 PM | #1 |
hillbilly
what is this?
I will have to post pics when I get home. I cannot post them from work. im looking for the door striker below the actual striker. it is oblong in shape and has two big Phillips screws going through it.it has a groove in the b pillar it slides in. mine are worn and would like replacement ones. if anybody knows what im talking about, what are they called and where can I get them? thanks
-1962 C-10 |
08-09-2013, 04:44 PM | #2 |
Re: what is this?
Ive always called them a wedge....don't know what they are technically called. Are they for your 62? I will check tonight and see if I have an extra set.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual http://67-72chevytrucks.com/vboard/s...d.php?t=519869 1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide http://67-72chevytrucks.com/vboard/s...d.php?t=619024 1964 Short bed trailer |
08-09-2013, 05:04 PM | #3 |
hillbilly
Re: what is this?
yes they are for my 62. let me know. couldn't find them in lmc.
-1962 C-10 |
08-09-2013, 07:43 PM | #4 |
hillbilly
Re: what is this?
-1962 C-10 |
08-09-2013, 09:53 PM | #5 |
Re: what is this?
It's called a door latch. Lmc has them. Part #7. On page 12.
http://www.lmctruck.com/icatalog/cbe/full.aspx?Page=12 |
08-10-2013, 12:49 AM | #6 | |
hillbilly
Re: what is this?
-1962 C-10 |
08-10-2013, 01:09 AM | #7 |
Re: what is this?
it was to keep the door aligned when closing i don't think they were need ( it looked good on paper lol ) i don't know if they were used in all years what year is yours? ill have to look at my 3 i have 60/62 a 63 and a 64/66
08-10-2013, 08:07 AM | #8 |
hillbilly
Re: what is this?
I have a 62
-1962 C-10 |
08-10-2013, 10:06 AM | #9 |
Re: what is this?
I have a spare I can part with, contact me via private message.
Jake Lacombe, LA.
http://s1299.photobucket.com/user/jb...23904108567829 |
08-10-2013, 10:37 AM | #10 |
1961 crewcab
Re: what is this?
they are needed , they put pressure on the upper latch and keep it tight, I left them off on the truck I sectioned, and went through hours of frustration trying to get the doors to latch right... It was only when I was putting another set of doors on a different truck, and ran into the same problem , that I figured out that adjusting the wedge was how to get the doors to latch.
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
08-11-2013, 11:19 PM | #11 |
Re: what is this?
i looked at my 65 c20 it never had them .... not set up for them at all
08-12-2013, 12:53 AM | #12 |
60-66 Nut
Re: what is this?
Only the '60-'63's had them.
08-12-2013, 12:54 AM | #13 |
1961 crewcab
Re: what is this?
in 64 with the new windshield, they updated the door latches as well, 64-66 door latches have no interchange with 60-63...
08-12-2013, 12:27 PM | #14 |
Re: what is this?
if they are worn (grooved) you can fill them with epoxy and file/sand smooth again. if you don't care what they look like i think you can switch sides (p/s to d/s) and flip them upside down.
1961 chevy K10 my build is------------61K10 build |
