Old 08-09-2013, 08:48 PM   #1
grs
Lock Up on trans.
I may buy a 63 with a 700R4 trans. The seller says the lock up will kick out and kick in while driving. Is this normal?
grs is offline   Reply With Quote
Old 08-09-2013, 08:54 PM   #2
grs
BowTie transmissions
Are BowTie trasmissions any good? And what other companies rebuild them?
Old 08-09-2013, 08:55 PM   #3
Irishbleueyes
Re: Lock Up on trans.
At cruise speed? Need more info.. its not normal at cruise. It locks up at cruise speed and then unlocks when you accelerate or tap the brake pedal. Does it have an automatic lock up? Some of them have manual locking.. Get more info
Irishbleueyes is offline   Reply With Quote
Old 08-09-2013, 08:57 PM   #4
Irishbleueyes
Re: BowTie transmissions
Everybody rebuilds them, very common. However Bowtie overdrives does a xlnt job. Read the info on their site and compare..
http://www.bowtieoverdrives.com/cata...SUBCAT&CATID=B
Old 08-09-2013, 09:15 PM   #5
grs
700R4 lock up
What can cause the trans lock up to kick in and out? It kicks in and out of overdrive. And are BowTie transmissions any good? And who else rebuilds them?
Old 08-09-2013, 09:20 PM   #6
grs
Yea I know a lot of shops rebuild them , but I don't know a good shop. I live in Roanoke, Tx. I just moved here from Joliet,IL. Thanks.
Old 08-09-2013, 09:25 PM   #7
grs
Thanks. I have not bought the truck yet. I was getting info to see if I should buy it or not. Maybe if I can get for $2,000 less that would cover a new trans plus labor. What is automatic, and manual lock up?
Old 08-09-2013, 10:38 PM   #8
Chevy Fleetside
Chevy Fleetside's Avatar
I wire mine up to a switch and lock it myself.
"A man and his truck, what a beautiful thing"
65 Short Fleetside BBC
65 Long Fleetside 283 3 on the tree for now.
my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536
Chevy Fleetside is offline   Reply With Quote
Old 08-10-2013, 07:42 AM   #9
tincan1966
tincan1966's Avatar
I would bet that the TV cable is not adjusted properly, as they are very particular in how they are set. Must be correct or trans failure can occur. Improper setting will cause it to seem very touchy and lock in/lock out with very little throttle movement.
Most will call it a "kick down" cable like on an old TH350 trans, but it is a throttle valve cable which controls fluid pressure inside the trans. Adjustment is critical to trans life.
Most any trans shop can adjust it for you, or you can search the web or here and find info. It is not complicated to do, just take your time and follow instructions.
tincan1966 is offline   Reply With Quote
Old 08-10-2013, 08:29 AM   #10
grs
Thanks everyone for the info.
