Old 08-09-2013, 09:36 PM   #1
Matt Cramer
1972 C10 long bed beater with a 4.8 LSx swap
Oops, accidentally put my build thread title here and my question in the build thread board.
So, I'm trying to fit a 4.8 into my '72 C10. Using the mounts that set the engine forward 3", what appear to be six cylinder engine stands, and the cross member redrilled to move the engine stands back about 3" to put the engine in the stock location.
The 4.8 truck manifolds don't fit too well:
They hit the engine stands (right now the motor is resting in the engine compartment, but the stands are pushed so far apart they don't reach down to the crossmember) and exit too close to the frame rails. So, I need some sort of manifolds or headers that give a lot of clearance between the first and second cylinders on each side. The Doug Thornley headers look like they'd work, but are on the pricey side. I've seen a few similar swaps where someone tried Trailblazer SS manifolds, and they didn't work. Fifth generation Camaro manifolds look like a possibility. But then I found these:
BBK LS3 / L99 shorty headers
Looks like it might work - and would be a bit easier to hammer a bit of extra clearance into if they didn't, compared to an iron manifold. Anybody tried these, or other fifth generation Camaro headers, in a '67-'72 C10? Especially with the mounts far back on the block like mine and six cylinder engine stands.
Matt Cramer
1972 Chevy C10 - 4.8 swap, long bed, and maybe one dent free body panel somewhere - SOLD
4.8 LS build thread
Matt Cramer is offline   Reply With Quote
Old 08-09-2013, 11:08 PM   #2
truckdude239
truckdude239's Avatar
Re: 1972 C10 long bed beater with a 4.8 LSx swap
I used the trailblazer ss manifolds
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 08-10-2013, 03:32 AM   #3
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Same, and with the 6cylinder stands and the engine that far forward, they will be one of your only options. The Dough Thorley header also fits but its much more expensive, though very very nice.
Some have also gotten the tubular fbody manifolds to fit, sometimes with modification. The new Camaro manifolds have also been used in a few configurations.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-10-2013, 07:55 AM   #4
Matt Cramer
Any pictures of how they fit? I've seen a couple pictures showing the TBSS manifolds hitting the six cylinder mounts, or coming so close you have to hack them up:
http://67-72chevytrucks.com/vboard/s...67&postcount=3
http://67-72chevytrucks.com/vboard/s...d.php?t=447751
Like the guy in that thread, the engine isn't very far forward - it's the mounts that are moved far backward. Mostly to clear the A/C compressor.
Matt Cramer
4.8 LS build thread
Old 08-12-2013, 11:23 AM   #5
Wasted Income
Boosted Member
Wasted Income's Avatar
Can't wait to see this truck running megasquirt
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 08-13-2013, 09:19 PM   #6
Leonard1
Leonard1's Avatar
I used the TBSS exhaust manifolds, and couldn't get them to clear the "humps" on the original perches. So I wound up using a set of 73+ perches.
Leonard1 is offline   Reply With Quote
Old 08-13-2013, 10:21 PM   #7
truckdude239
Ill load me tomorrow but the tb ss manifold cleared perfect on my 71 with dirty dingo silder mounts with the oringal perches
David fuller
2000 Tahoe 5.3l 378
Old 08-22-2013, 06:09 PM   #8
Matt Cramer
It looks as if my reputation has preceded me here. It's going to be running MS3.
Matt Cramer
4.8 LS build thread
Old 08-26-2013, 09:31 AM   #9
Wasted Income
Boosted Member
Well anyone who has spent as much as much with DIYAutoTune as my brother and I have, knows the name Matt Cramer.
Turbo diesel
