08-09-2013, 10:36 PM | #1 |
Transmission Problem
So my problem is that my 68's transmission isn't shifting right. Fluid level is right and I believe the TV cable is adjusted right. Its not the firmness of the shifts just the timing more or less. It winds to roughly 4k and has to kinda hold there for a second before it'll shift out of 1st gear.
I was just wondering what advice you all had for it. I've not had time to actually work on it for a while. It was shifting fine a few months back but I ended up moving around not really able to drive it or move it with me until about 2 weeks ago. Honestly I think it just needs drove a little to work things free. But I've been afraid to drive it much so that I don't burn up anything in the transmission. Its a '83 700r4 that was rebuilt about a year ago but I'd guess less then 5k miles on it since it was built. |
08-10-2013, 09:13 AM | #2 |
Re: Transmission Problem
Sounds like the TV valve might be sticking.
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
08-10-2013, 01:11 PM | #3 |
Tv valve or the govenor sticking,I would pull the govenor first and see if it is sticking,u will only lose a small amount of fluid.If that is OK then drop the pan and have a look see alot more messier if u don't have a drain plug.
2001 Silverado K-1500 2005 FXDWG stage3 69 CHEVY Short/Step 327/4L60 373 posi 63 IMPALA 327 |
08-10-2013, 08:18 PM | #4 |
A pressure gauge is the Best tool for diagnosing this problem.
08-11-2013, 09:12 PM | #6 |
If Line Pressure is above 100 psi idling in park......The TV valve or Plunger is sticking or stuck.
Tags |
transmission |
