Old 08-10-2013, 10:38 AM   #1
Avalance1
Wheel cylinder help please
Attached is a pic of my wheel cylinder that I need to remove but there are no bolts on the back side as the manual says is the way to remove it please help.
Avalance1 is offline   Reply With Quote
Old 08-10-2013, 07:23 PM   #2
gdavis
gdavis's Avatar
Re: Wheel cylinder help please
looks like the big nut is your only choice or get another backing plate. I would go with the big nut. with heat first.
Check out Patches
Cars I owned in the past.
1962 chev II Nova - 1965 Chevelle SS - (2)1966 Chevelle SS 1965 chev C10 57 belair chev
1967 Chevelle SS - 1969 Chevelle SS - 1972 Chevelle SS
1967 Buick electra 225 1995 Harley Davidson bager
What does not kill you will make you stronger
1968 c10 short wheel base stepper
gdavis is offline   Reply With Quote
Old 08-10-2013, 08:13 PM   #3
Avalance1
Old 08-10-2013, 08:14 PM   #4
Avalance1
Thanks was not sure as there is no threads and really tight,I will send u a message when it's off
Old 08-11-2013, 01:41 AM   #5
franken
It's old time advice, but there are wheel cylinder hones (some are essentially a rod w/ sandpaper) that will clean up the bore and let you put in a $5 kit to rebuild the wheel cylinder.
Other than that, I'd impact that pup out...
franken is offline   Reply With Quote
Old 08-13-2014, 03:19 PM   #6
mikewoods
mikewoods's Avatar
Sorry for digging up an old thread, but what size is that nut?! 27mm is too small 30mm and 1 1/4 are too big. I don't have 28 or 1 1/8. is that what I need?
"The Mustang’s front end is problematic, get yourself a Firebird. "- Red Forman
mikewoods is offline   Reply With Quote
