Which motor should I go with?
Should I go with a 525hp LS 3 or a big block with roughly same hp?
![]() Join Date: Aug 2012
Re: Which motor should I go with?
I wish I had this dilemma...
without knowing more, I would say the LS on the basis of less weight. but that's my $.02 |
LS no brainer...
Big blocks sound so good though!
My Lost and Forgotten build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=442712 |
Was going with the LS untill I drove my buds 70 Chev it's got a 468 with a procharger. Man that thing sounded good.
you want to drive it or race it?
either suggestion screams 4 mpg
cool, an ogre smiley ![]() how to put your truck year and build thread into your signature shop air compressor timer |
![]() What do folks get with a little, mostly stock 350, HEI, Edelbrock manifold w/4bbl ? I am happy when I get 10mpg on premium. Last edited by Highsider; 08-10-2013 at 08:02 PM. |
define stock? i have a stock gm ramjet 350 that gets 20 mpg
why do you run premium? premium fuel will typically get worse mileage than regular. premium fuel is mainly for higher compression motors that have a destructive knock when run on regular high compression motors typically are also high horse power, thus people equate more hp with premium fuel premium fuel will actually decrease your hp
Truck mite see the track the odd weekend but mostly be street/show. I need to pull the trigger soon on the motor and trans so I can mock it up. Any thoughts on a auto trans?
Run the LS3. You will get big block hp and tq but great fuel mileage too assuming you go with EFI. As for a trans I would either run a 4L80E or a 6L90E. The 6-speed auto is really a nice transmission. If you want to go manual just throw a T-56 or TR-6060 in there. For fuel just grab one of the new aftermarket under bed tanks and throw the new Aeromotive in tank fuel pump in it. It's a universal kit and will support up to 700hp for EFI. Its an easy install and you don't have to worry about baffling the tank or having fuel starvation problems.
1952 3800 GMC 2008 Harley VRSCDX 2011 Road King Classic 2012 Sierra Denali 2500HD 1966 Datsun Roadster 1600 1965 Chevelle SS |
Hmmm....
You wouldn't choose a 1970's projection TV over a modern HD flat screen would you? Go with the LS engine! |
Navy Radioman Veteran
This is what I'm putting in my '57 Stepper. LS3 Connect and Cruise Kit.
http://www.chevroletperformance.com/...systems/#ls3_k
1987 Chevrolet R10 Silverado BBC Build thread - SOLD 1986 GMC Sierra Classic - SOLD 1957 Chevy Step Side - At the Body Shop Daily Driver; 2005 Chevrolet Silverado 4x4 Z71 Stepside |
#12 | |
#13 |
Nothin wrong with a big block!
#14 | |
best thing i could have done for my truk. ![]() plug and play for sure other than oil changes, i've done nothing to it
#15 | |
either way itll be sweet
68' c10 stepper 5.3/4L60e Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=578917 |
#16 | |
-Joe Posted via Mobile Device |
#17 |
Just switched to that exact setup from a 2bbl. Initial results show 14.5 mpg with regular fuel, up from the previous 8.5mpg 2 barrel hog!
#18 |
I made up my mind LS it is. Thanks for your help guys I will update my build when I get time to sit for more than 2 min's.
#19 |
Great choice if the budget will support it.
I'd think seriously about setting the whole drivetrain up so that in the end it was effectively geared out where the rear tires meet the ground pretty well the same as a performance car that engine would come in. Meaning match your tire outside diameter and rear gears to emulate the gearing in a Z Camaro or Corvette that might have that engine/trans combo. That way you will have a pretty quick truck that will also handle serious road trips and pull decent fuel mileage.
