08-10-2013, 02:32 PM | #1 |
Quick drip rail repair?
The wino who painted my truck a while back did a poor job (at best) on the drip rail. Now it is all cracked and I am afraid water is getting in where it doesn't need to be (unfortunately Ole Green lives outside right now).
Is there something I could patch it up with to stop further damage until I can get it fixed properly? Thanks for any input.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives |
08-10-2013, 02:37 PM | #2 |
Re: Quick drip rail repair?
You need to clean all that out and use a drip rail caulk. There are a lot of threads covering the subject, but honestly it just adds to my confusion about what product to use. Good luck!
Posted via Mobile Device |
08-10-2013, 03:30 PM | #3 |
I just repaired mine by cleaning all the old out with a brass wire brush in a die grinder, treating with POR15 then SEM heavy build self leveling seam sealer. planning on painting very soon
08-10-2013, 06:03 PM | #4 |
There's no such thing as a quick drip rail caulk repair, unless you want to be redoing it again soon
Here's my thread on the topic. Scroll to the last page to see how I did it. The product I used is awesome, and doesn't require a special caulk gun, even though it's a two part epoxyhttp://67-72chevytrucks.com/vboard/s...rip+rail+caulk Posted via Mobile Device |
08-10-2013, 08:35 PM | #5 |
I agree 100% on the por 15 and self leveling drip check.
08-11-2013, 01:06 AM | #6 |
My opinion is get the sealer out, then the rust, then fix the metal. From the amount of rust it looks like the metal is rusted through so you've got trouble. Old vehicles rust from the inside out so what you see is the tip of the rustberg.
POR is another bandaid so you'll be back fixing it in a few years. A wire brush polishes rust, making it look like metal. Run some sandpaper over it before believing your eyes. |
08-11-2013, 12:10 PM | #7 | |
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
08-11-2013, 04:19 PM | #8 |
Try OTE=kcsa75;6215076]Just read through your thread and have one question: Was there any problem getting the sealer to stay put on the vertical part of the rail behind the door?[/QUOTE]
make a little catch at the bottom with some tape and then slowly go over the area 2 or 3 times Posted via Mobile Device |
08-11-2013, 11:41 PM | #9 |
A tarp would work in a pinch. You could use the spare tire to hold it down when parked. Not very appealing but anything else short of doing it right will just be a mess.
Dane 67 Chevy Fleet 250/4 speed 1/2 ton 68 Chevy 250/4 speed 1/2 ton for parts 49 GMC Grain truck 235 1 1/2 ton 76 Chevy 350/4 speed 1/2 ton |
