Brake drum assembly question.
It's like everyday I need to ask ya'll something!
I tore down the driver's side (rear) drum and brake assembly, used my dremel tool's wire wheel to clean off all the rust (a lot of it) but the little geared wheel on my adjuster/pivot nut WILL NOT TURN. The Haynes book I bought suggested replacing it. Naturally Advance Auto has never heard of it for that year (rather like the radiator you guys suggested and I bought from them). Anyone have an Advance Auto part number for me? Should I just soak this thing in something? Here's a pic, if I get it to work. (Oh yes, I wore a mask and goggles for the brake cleaning) http://i1313.photobucket.com/albums/...ps4828e6a8.jpg Oh, and I could not for the life of me disconnect the parking brake from the actuator so I just cleaned the actuator as it hung there. Is that normal? |
Re: Brake drum assembly question.
Can't speak for Advance, but I know both Napa and Autozone carry them. They are left and right specific.
I prefer to replace them, as they will lock up again pretty quickly once they have some corrosion in them.
Shawn 1970 Chevy C-10 SWB, 350, TKO 600 5 speed My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881 |
Thanks man! I just called NAPA and they're going to order both adjuster assemblies and set both sets of spring kits aside for me.
My springs were still serviceable I'm sure but they were pretty rusty. I think my shoes looked pretty good....but seeing as I've never seen a set of brake shoes before I am not be the best judge! ![]() Now if I can just get everything back together! Would it be a good idea to go ahead and flush out the old brake fluid? If so, what is a good 1-man kit to do that with? |
Moderator
![]() Join Date: May 2007
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
#6 | |
I have a MityVac that works well. Got that at Harbor Freight, but seen them other places too. Definitely a good idea to swap out the fluid, it can get water in it over time.
#7 | |
Here's a trick for removing the park brake cable from the backing plate. Use a small hose clamp, open it up, slide it over the cable and over the little tangs where the cable comes thru the plate. Tighten it enough to collapse the tangs and the cable slides right out. |
The wide gear looking bit in the pic is the star wheel. I'd leave the whole thing in oil/atf or something (not WD40) overnight and it will free up.
BTW, the purpose of that thing is the autoadjuster so when you back up and stop, it adjusts the shoe out if needed to keep the brake pedal high. Or at least that's how I think it works. If I'm full of crap, I'd appreciate being set straight. Truth trumps pride (or whatever)? ![]() |
#10 | |
THe star wheels purpose is primarily to provide a way to adjust the brake shoes from outside the drum thru the access hole in the drum or backing plate. Second it provides a handy place that the self adjuster arm can contact to keep the shoes adjusted close to the drum. You can remove the self adjuster but you'll need to manually adjust your brakes to keep the shoes close to the drum. Some of the first cars I worked on had no self adjusters. Once a month you got out your trusty brake tool (screwdriver) and took out the slack. |
Here is some advice...... AVOID ADVANCE AUTO PARTS!!! go to napa... i bought 6 brake kits 2 hardware and 4 self adjuster kits for 74 bux... advance like you said never heard of them... luckily i have a small family owned napa near my house even bring them coffee sometimes haha
I am a Referee of life.
Here's a bit of advice for what it's worth.When you get those adjusters freed u and cleaned.Assemble them with anti sieze on the threads only.They should stay free and easy to turn for a long time.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
#13 | |
I have two Advance, two O'Reilly's, two NAPA and a CarQuest distribution center with an attached store within 10 minutes of my house. For the reasons stated above, Advance is my first choice.
Willie Swamp Angel Truckers '72 C10 Highlander ![]() People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. ![]() |
#14 | |
#15 | |
Also I don't see the lube for the backing plate .
My Classics: '72 K20 Suburban + '65 Dodge Town Wagon '72 Corvette Roadster +'67 Corvette Roadster '73 Z-28 Camaro '63 Ford SWB Uni Pickup '50 Ford Coupe |
#16 | |
Moderator
#17 |
I think it's good he has the short in front and the long in back because that's the way it is supposed to be.
Lube on the shoe rests is optional. Some do, some don't. |
#18 | |
Short lining - FRONT Long lining - REAR
'67 C20 small window Fleetside - 250 inline 6 - 3 on the tree - heavy duty clutch, brakes, rear springs - 17.5 wheels w/bias ply tires - AM radio - heater. |
