Old 08-10-2013, 06:43 PM   #1
Drewski23
Frame painting/coating options - What did you use on your frame
I am beginning to clean the frame and i started by using a twist knot wire wheel on an angle grinder, stripping all the old stuff off completely...I havent done a ton of it yet. I was planning on using POR 15. Ive heard POR doesnt actually stick well to smooth surfaces even when you use the marine clean and metal ready. I was planning on top coating it also which means i have to use the tie coat primer i guess, then the top coat...3 coats of this ****? sheesh...then i still have to buy the metal ready and marine clean for it too..maybe there is a more economical alternative product that i dont know of
Alot of people say it works fine..on smooth surfaces, i dont know. Anyways im just wondering what you all have used and what your results were. Im not going to be spraying any coating on, unless there is a good rattle can product. It will be something brushed on...let me know, thanks
Drewski23 is offline   Reply With Quote
Old 08-11-2013, 04:42 AM   #2
nobolt
nobolt's Avatar
Re: Frame painting/coating options - What did you use on your frame
the way I understand it, the metal ready/prep ready etches the smooth surface while it converts the rust.
i'm going to use it too, but never used it before this.
Dave
"... government even in its best state is but a necessary evil. Thomas Paine
"It wasn't a lie, it was ineptitude with insufficient cover." Donald Draper (Mad Men)
nobolt is offline   Reply With Quote
Old 08-11-2013, 11:04 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
I've had adhesion issues with POR15 several times when I went over smooth metal. However, over sandblasted metal, you won't ever get it off. It definitely needs tooth to adhere to.
Old 08-11-2013, 11:57 AM   #4
dennislbrooks
dennislbrooks's Avatar
With frame exposed, I took off all the loose rust and dirt of by any means including wire brushes and in places with a sanding wheel. I gave it a couple of thorough washings and a good dry in the heat of Dallas TX. There are other good products out there but I like Zero Rust. I thinned it slightly then rolled most of it on with a non fuzzy 2 " roller. Some places I used a small brush and a rattle can of the same stuff. I use the same stuff on my axles front and back. Great adhesion and wants to be as close as it can to the metal.
dennislbrooks is offline   Reply With Quote
Old 08-11-2013, 12:00 PM   #5
Gene
Gene's Avatar
Had mine blasted and powder coated for $400.
1971 SWB 4X4 Build
BOARD MEMBER #5448
BOOMER SOONER!!!!
Gene is offline   Reply With Quote
Old 08-11-2013, 01:51 PM   #6
67ctener
67ctener's Avatar
Also had mine powdercoated wouldn't do it any other way
Scott
67 c10 sold
89 c1500
90 k2500
91 s10
#chevyonly
67ctener is offline   Reply With Quote
Old 08-11-2013, 04:21 PM   #7
Tillik
Tillik's Avatar
My original plan was to PoR-15 mine. My friend is a painter and has suggested I just paint it and use a Flex-All additive to the clear coat. I am a long ways away from doing a frame-off so I've got plenty of time to figure it out.
James B.
1967 Chevy Fleetside Shortbed 4X2 (Black & Beautiful)
1971 Chevy Fleetside Shortbed 4X4 (White & Rough)
Tillik is offline   Reply With Quote
Old 08-11-2013, 04:36 PM   #8
Special-Ed
Special-Ed's Avatar
powder coat is my suggestion
Ed will be known as the Tiger Woods of the integration business
Special-Ed is offline   Reply With Quote
Old 08-11-2013, 05:02 PM   #9
HotRod C/10
HotRod C/10's Avatar
I used Black Enamel Tractor paint. Tough stuiff
SOLD -77 CHEYENNE SWB,
LS SWAPPED
-1976 SILVERADO
YUBA GOLD/NEUTRAL (2-TONE)
HotRod C/10 is offline   Reply With Quote
Old 08-11-2013, 06:16 PM   #10
Drewski23
well i dont have the entire frame off right now..this is how it sits. i figured id paint the front part of the frame and crossmember now with something cause im re doing the engine bay and suspension, and do the other two sections as i moved on to other parts of the truck...
Old 08-11-2013, 09:25 PM   #11
Sammy
I used the POR 15 chassis coat. Looks good and hard as nails.
From cheapest to most durable and expensive. tractor implement paint, POR 15, then the powder coating. Depends really on your time n funds.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL"
"You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig."
ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629"
Sammy is offline   Reply With Quote
Old 08-11-2013, 09:43 PM   #12
67c10rustbuket
67c10rustbuket's Avatar
Tractor paint from tractor supply
Aka
"Farm and implement" paint
Comes in quarts gallons and spray cans. You will find out real quick that it is not a typical spray paint. It is thick thick thick!
Frame was sandblasted and sprayed with primer first. I would have powder coated but had several repairs and mods to do first.
Dan <---(my name)
67 SWB C10 project "GEORGIA"-59 Brookwood 2dr wag...Next project-03 Tahoe 4x4 5.3 family ride-07 Hondur Accord, commuter car
67c10rustbuket is offline   Reply With Quote
