Old 08-11-2013, 12:31 AM   #1
track70
track70's Avatar
Which Clutch Fork?
Alright guys i picked up a muncie 4 speed for my C10 and was wondering which clutch fork i need to use to make it work..And also will the stock c10 manual linkage work with trans! Thanks!
TRACK70 BUILD -> http://67-72chevytrucks.com/vboard/s...d.php?t=589761
King's Speed Shop
track70 is offline   Reply With Quote
Old 08-11-2013, 07:38 AM   #2
midniteblues
midniteblues's Avatar
Re: Which Clutch Fork?
the oe clutch fork should be just fine.
i'm not sure witch muncie you have but some have fine spline input shafts an unless the clutch disc was changed the fine splines are not gonna fit your disc.
when you say "stock c10 linkage" do you mean the colum shifted 3 spd linkage? if so you'll be missing 4th gear.
sounds like your gonna want a 4 on the floor shifter. witch requires cutting a hole in the floor.
81 camaro 355 4/spd 342 posi my first love.
67 swb step 454/4spd ott 373 posi 4/7 drop.
2000 s10 zr2 little blue truck that never gets stuck.
'74 heald super bronc vt8. tecumseh powered moon rover.
midniteblues is offline   Reply With Quote
Old 08-11-2013, 01:15 PM   #3
track70
track70's Avatar
Hey Thanks for the info..ill get a stock clutch fork then..And i was asking about the linkage that comes from the pedal to the fork! Just a little more info..I'm converting my th350 to a 4 speed..the trans i got did not come with a bellhousing..Is there a certain one i should look for to use! Thanks!
King's Speed Shop
