Old 08-11-2013, 09:27 AM   #1
jons70
Tremec Swap
Has anyone done a Tremec swap with a big block? Pics?
jons70 is offline   Reply With Quote
Old 08-11-2013, 09:48 AM   #2
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Tremec Swap
Yes, I have. what pics do you want?
Tom Vogel is offline   Reply With Quote
Old 08-11-2013, 10:06 AM   #3
jons70
Re: Tremec Swap
Geeze Tom, I go from trying to buy a big block fan shroud off you to seeing what your Tremec swap looks like! LOL
Basically I want to see where your shifter is and if you have headers, how your clutch linkage sits. My truck currently has a small block in it with a Muncie M21. The problem is that I think I might have to move the motor mounts to the forward position to clear the firewall with the valve covers on the 454 and I don't know what that will do to the clutch linkage and the headers. I also want to swap out the original bell housing with the mounts to a traditional aluminum one without the mounts
Old 08-13-2013, 09:39 AM   #4
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Tremec Swap
Ill get the pics tonight.
Old 08-13-2013, 11:03 PM   #5
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Tremec Swap
Heres the shifter position, its a McCleod shifter and a Hurst stick
Old 08-13-2013, 11:06 PM   #6
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Tremec Swap
Z-bar
Old 08-13-2013, 11:07 PM   #7
Tom Vogel
2WD Jimmy
Tom Vogel's Avatar
Re: Tremec Swap
One more...
Oh... also, the engine is in the stock position. I used tall fabricated valve covers that I trimmed alittle on the drivers side to clear the firewall.
Old 08-14-2013, 08:18 AM   #8
BossHogg69
motor exploder
BossHogg69's Avatar
Re: Tremec Swap
I have, but I used a McLeod hydraulic throwout bearing, so header clearance wasn't an issue.
Adam
1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac
1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's
1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac
2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80
2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac
Use the SEARCH function on this forum - it is your friend!!
BossHogg69 is offline   Reply With Quote
Old 08-15-2013, 10:33 AM   #9
jons70
Re: Tremec Swap
Originally Posted by Tom Vogel View Post
One more...
Thanks for the pictures Tom, they're definitely helpful with my build. The only thing that's different about yours is the you have a tall hump and mine is the low hump. Your crossmemeber is also different and I'm going to use the factory bell housing and remove the rubber mounts.
I ordered the Tremec yesterday
-The tranny(TKO-600 w/.64 OD)
-Slip yoke(Not sure what position my engine is going to be in for the length of the driveshaft yet)
-Speedometer cable w/adapter
-Reverse light pigtail
-Crossmember(flush with the underside of the frame)
-Urethane tranny mount
-Hardware kit
-Hurst mid shift billet conversion installed(to keep the shifter handle away from the bench, like yours)
Looks like the headers clear the Z bar with plenty of room. Is the Z bar new on your truck? I might need a new one for my truck because someone butchered it to clear the headers on the small block that's in the truck now.
