08-11-2013, 03:46 PM | #1 |
What is this wire supposed to connect to
This wire is wrapped in with other factory-installed wires that connect through the plug on the right. Any idea what it does or where it goes?
Willie Swamp Angel Truckers '72 C10 Highlander People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't. |
08-11-2013, 04:13 PM | #2 |
Old member
Re: What is this wire supposed to connect to
No picture for me.
08-11-2013, 04:20 PM | #3 |
I see the pics, but cant help with the wire.
1972 Cheyene C-10 "Ole Green" My Grandfathers truck (early 70's to 1983) My first vehicle (1983) Original 350 (3 rebuilds) 700R4 from Bowtie Overdrives |
08-11-2013, 04:39 PM | #4 |
No picture here either.
Posted via Mobile Device |
08-11-2013, 05:13 PM | #5 |
My thought, if it is pink, is the idle stop solenoid found on some trucks. Best thing to do is trace it and match it up to the wiring diagram in the 72 factory service manual. It can be downloaded here.
http://67-72chevytrucks.com/vboard/s...d.php?t=558016
Thanks, Tim * VIN/Model Decoders * Power Team Charts (engine/transmission/gear ratio) * Post Your Pickup SPID ** Blazer SPID ** Suburban/Panel SPID * RTFM ... Read The Factory Manuals... download 'em here Highlanders ** Do you have a 1972 Plaid Pickup? ** Plaid Blazer ** Plaid Suburban |
08-11-2013, 08:16 PM | #6 |
I am not certain without looking at a wiring diagram, but I was thinking carburator electric choke?....... Nope I just looked at the wiring diagram and I am pretty sure it is the idle stop solenoid wire.
08-12-2013, 10:18 AM | #7 |
So I'm curious, since I just found the same wire. I've got a mystery 350 with a new(ish) Edelbrock Q-jet. Is there any need for that circuit or can I use it to power the electric choke?
08-12-2013, 11:43 AM | #8 |
I used it to power the electric choke. keyed on power wire
Mike 2001 Dakota R/T - Silver CC - 1 of 1671 •360 w/46RE •392 limited slip 1972 Chevy Suburban - Turquoise/Black 1969 Chevy C/10 - Blue LWB •350 w/ 700R4 •3.73 posi •PS PB A/C - SOLD Using your turn signal is not "giving information to the enemy" 67-72 FAQ |
08-12-2013, 12:11 PM | #9 |
That looks like the HEI wire to me.
08-12-2013, 01:03 PM | #10 |
Is the AC working properly? What year truck?
'67 GMC 2500, 292, 4spd, AC |
08-12-2013, 01:31 PM | #11 | |
Thanks for the replies.
Nope. HEI is working fine. AC works fine on my 72 Chevy. As for the idle stop solenoid, the carb doesn't have one and this wire "appears" to be factory and is routed to the passenger side of the truck. Wouldn't the solenoid be on the throttle linkage on the driver side?
08-12-2013, 01:34 PM | #12 |
Maybe a fan wire in a non-a/c harness that is not used in an a/c truck? Does it have power anytime?
I would trace it back to the firewall bulkhead and then inside and see where it connects.
'83 K20-TPI '73 C10 '79 C10-ex-diesel(SOLD) '07 Tahoe(Son driving) '14 Suburban-DD '71 C10-current project |
08-12-2013, 03:33 PM | #13 |
I have a pink wire that looks just like the one in the pictures connected to idle stop solenoid on mine.
1972 C10 LWB, 350/350 Deconstruction began 5/2009, mostly completed restoration, 5/2017 |
