Old 07-04-2003, 12:43 AM   #1
iufan71
Air Conditionig Repair--where to start?
Ok,i have a 78 GMC,and it has Air on it,but its not working right now. Where do i start and what do i look for as far as figuring out what works and what my problems are? I know one of the a/c hoses has duct tape on it,so im almost positive it has a hole in it and needs to be replaced. Since there is only 3 a/c lines that i see,i thought of just replaceing those to start with. I have a 350 with auto. tranny. Any help is appreciatted.
iufan71 is offline   Reply With Quote
Old 07-04-2003, 02:40 AM   #2
Joe Rae
Yes, replace hoses and condenser, have it evacuated, charged, and see if it holds charge. Condenser needs replacing due to excess moisture from leaks. I spent around 200.00 on hoses, condenser, charging, etc. My compressor is working fine.
Joe Rae is offline   Reply With Quote
Old 07-04-2003, 06:05 AM   #3
apstguy
LED King
apstguy's Avatar
If you are staying with R-12, then do as Joe said above. You will probably need a new compressor. If you are going to switch to R-134a then you will need all of the above plus a new orifice tube, high pressure cutoff, a really good flush. Don't forget to get new o-rings!
Tyler
1985 C10 305 w/ Bowtie OD TH700R4 3.42 LSD 202,000 miles
2006 Ford Focus ZX3 5-speed Stick
2016 Chevy Spark EV
Gone: 2002.5 VW GTI 24v VR6
Gone: 2008 VW R32
apstguy is offline   Reply With Quote
Old 07-04-2003, 09:42 AM   #4
iufan71
A/c problems
Wouldnt you have to convert to the newer freon anyways,since no one will mess with the old stuff?
Old 07-04-2003, 12:57 PM   #5
Joe Rae
I chose not to convert due to having a supply of R12 available. Once I run out, I'll be forced to, or check classified ads. As far as servicing? I've never had a problem... One thing I've received from LMC that was good quality/price was their replacement hoses. When my compressor goes, I'll switch. apstguy makes good point, probably right time for you to switch over $ permitting.
Old 07-04-2003, 02:45 PM   #6
DrMaserati
Village Curmudgeon
There should be no need to replace the condenser. It is not affected by moisture and doesn't retain any, but should be flushed. Are you sure you didn't mean to say the accumulator or receiver/drier? That unit should definitely be replaced for that reason.
JP
78 Chevy K30 duallie, 454, TH400
78 IH Scout II, 4X4, 345, 727TF
76 IH Scout II, 4X4, 345, 727TF
65 IH 1200C pickup, 4X4, 345, 4 spd
48 IH KB-8-F, RD-450, 5 spd, 35,000 GVW (a REAL truck)
"Life is too short to drink cheap beer." Harry S. Truman
DrMaserati is offline   Reply With Quote
Old 07-04-2003, 06:54 PM   #7
Joe Rae
Yes accumulator, thanks!
