Old 08-11-2013, 10:01 PM   #1
DieselRat
Show me your gas pedal setups for s10 frame swap
Hey all, instead of wading through each build thread to find pics, I was hoping maybe someone could show me your gas pedal setups after doing an s10 frame swap.
I used the original brake pedal/hanger, and the clutch is going to be a whole unit but I am brainstorming for the gas pedal setup. I have the stock s10 pedal and bracket which I think should work fine, but I want some ideas to go by before I start cutting and fabbing. Thanks!
DieselRat is offline   Reply With Quote
Old 08-12-2013, 06:43 PM   #2
Clay54
Re: Show me your gas pedal setups for s10 frame swap
Just trying to keep this post alive. I would also like to see as well. Clay
Clay54 is offline   Reply With Quote
Old 08-12-2013, 08:39 PM   #3
Atommik
Atommik's Avatar
I used a Lokar gas pedal mounted to the floor and a throttle cable from Mr. Gasket.
Atommik is offline   Reply With Quote
Old 08-12-2013, 11:27 PM   #4
D-man313
D-man313's Avatar
What he said.
Mom, I think I may have broke something. My tires keep spinning and leaving black marks every where
D-man313 is offline   Reply With Quote
Old 08-21-2013, 01:10 PM   #5
rollinrooster
rollinrooster's Avatar
Lokar is the way to go!!!
rollinrooster is offline   Reply With Quote
Old 08-21-2013, 05:13 PM   #6
NEWFISHER
NEWFISHER's Avatar
As mentioned, the Lokar floor mount works well. it comes with the firewall side bracket and easy hook up with their universal cut to fit cable system. If you are using the S10, it will bolt to the inside and you will just need to fab a bracket on the firewall side to hold the cable housing.
NEWFISHER is offline   Reply With Quote
