Old 08-12-2013, 12:02 AM   #1
TacBlade
I need some pics of Exhaust & how its been routed?
I have a 1970 Chevy Shortbox fleetside. I need to figure out the best route for the exhaust to come out the rear? The exhaust guy wanted to cut holes for it through the beam that the stabilizer bars connect to? I told him to hold off on that, as there has to be a better solution?
TacBlade is offline   Reply With Quote
Old 08-12-2013, 12:18 AM   #2
jons70
Re: I need some pics of Exhaust & how its been routed?
I was planning to do the samething with my truck to get better ground clearance. They make new trailing arm crossmembers with 4" holes cut in them for guys with slammed trucks. They have a heavy steel ring welded around the holes for strenght though. My plan for mine is to drill 4" holes through it on both sides of the trailing arms and then weld a piece of 4" steel pipe all the way around to give it strenght back again.
jons70 is offline   Reply With Quote
Old 08-12-2013, 12:51 AM   #3
wreckedchevy
wreckedchevy's Avatar
this is how my exhaust guy ran mine 200,000 miles of rough Montana roads still holding up good. hope it helps
1969 Chevy C10 2wd stepside longbox
wreckedchevy is offline   Reply With Quote
