Old 08-12-2013, 12:17 AM   #1
endlessearth
endlessearth's Avatar
Using CLR on surface rust. How am I doing?
After seeing a really nice patina'd truck this weekend that had been waxed, I decided to try CLR on a couple areas of my truck to see how it would work. Here is what I did:
1. Clean area with cloth and dry thoroughly.
2. Apply CLR with a common household dish washing sponge (has a bit of plastic mesh on one side but is far from being a scouring pad.) Use moderate elbow grease.
3. Wash with clear water and dry.
4. Re-wash with water mixed with baking powder to neutralize any residual CLR.
Here are the pics:
Rear of passenger bed side. This is what it looks like pre-CLR.
Rear side of driver's side bed side. This is after CLR. It looked like the pic above beforehand.
In this pic, I used CLR on the lower left of the tailgate where it meet's the driver's side bed side . It was previously orange with rust all the way to the bottom. Should I continue? There isn't much paint left and a lot of the undercoating is going to show when I am done.
This is a before pic of the back half of the passenger side bed.
This is an after pic. I only focused on a few of the rust spots. You can see again that light rubbing with the sponge is exposing more of the primer. The paint on this truck is pretty shot.
Here is one last shot. You can see the area above that I worked on and how the rest of the panel looks.
So, here are my questions:
Do you recommend that I continue?
Should I retain same technique and tools or alter it?
I think the truck will look good with the rust removed and a nice coat of wax to protect it but I don't think that there is going to be a lot of tan paint left on it when all is said and done.
Thanks in advance,
Grant
endlessearth is offline   Reply With Quote
Old 08-12-2013, 12:31 AM   #2
slepysal
slepysal's Avatar
Re: Using CLR on surface rust. How am I doing?
It comes down to one question: Are you happy with the results? If so go for it! Keep in mind that in the end it is your truck, so build it the way YOU want.
Looks like a lot of hard work, but then again if it was easy everyone would do it.
And for what it is worth............. I like it, good job .
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes.
"Over, Around or through it... "
slepysal is offline   Reply With Quote
Old 08-12-2013, 01:15 AM   #3
oem4me
oem4me's Avatar
Results vary, but I personally have been down that same road with the same color paint, and I concluded it was best to leave it alone. Mother nature has slowly worked her magic over the last forty years, and all it takes is ten minutes to make it look ..well, unnatural. I say if the underlying paint is robust enough to take a polish, then maybe .. but if not, just let it be.
Old 08-19-2013, 10:25 PM   #4
endlessearth
After trying small areas as samples I went ahead and did the work. I used a sponge with the CLR rather than a scotch brite pad so I could work in layers and to be certain not to remove any paint from underneath. It took a lot of hours but once I got going I lost myself in it. I didn't do the tailgate, front end or roof. I feel that is was a bonding experience with my truck It was however a bit hard on my fingertips. I then washed the truck and waxed it with a high quality clear wax. I love how it came out. It isn't a very large difference from before hand but now light plays more off the different surfaces and I appreciate the lines better and I think that the panels have more depth to them. It especially pops at night under street lights. I have seen other trucks in other colors or with other types of aging that I would never do this to but I love how it worked out with this one. Plus, it kept me busy until I can afford more $$$ upgrades.
Old 08-19-2013, 10:59 PM   #5
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Heck that looks great!
Some guys do what you did and shoot clear over it instead of wax. I like what you did!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 08-19-2013, 11:23 PM   #6
19666Trucker
19666Trucker's Avatar
Looking good endless,
19666Trucker is offline   Reply With Quote
Old 08-19-2013, 11:47 PM   #7
C/10 King
C/10 King's Avatar
Looks great! Now lets see some close ups of the doors.
C/10 Rene
1966 Short Fleet "The Hag"
1967 CST Short Fleet "Dark Poly"
1971 Short Fleet
1970 Jimmy Custom 2 WD "Golden Ticket"
1972 Blazer 2 WD "Retro Blaze"
C/10 King is offline   Reply With Quote
Old 08-20-2013, 12:05 AM   #8
endlessearth
Thanks guys! Here is a close-up of the door.
Old 08-20-2013, 12:08 AM   #9
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Man! That looks awesome.
I'd say the body is done. - Seriously
66 C20 Service Truck:
Old 08-20-2013, 12:12 AM   #10
endlessearth
I think so too...except I might try and pull the dents in the doors out a bit. I purchased a suction cup-style dent puller from Northern Tool.
Old 08-20-2013, 12:21 AM   #11
LostMy65
LostMy65's Avatar
Before you attack any dents, please search the internet for videos on the subject.
I don't know, maybe you already know the tips and tricks, but I always just started from the deepest part of the dent and started pushing or pulling things out. But I guess the idea is to remove the dent in reverse of the way it occured. 'First in - Last out'
First In Last Out
Regardless of the tools you select to repair a dent, the same strategy applies. That is, first in last out. In other words, reverse the damage. Do not go straight to the point of impact and try to start pulling the damage out. This will lead to stretched metal and chasing the damage around.
Start with the indirect damage and move towards the direct damage. This will assure the metal is straightened back to it normal state with minimal stretched metal.
Old 08-20-2013, 12:29 AM   #12
Rich 5150 69
Rich 5150 69's Avatar
Truck looks sweet....!
`64 C10 vortec 350/350/373 posi
`69 RS/SS 350/350/308
`37 Ford 406/350/324 traclock
`68 Dart 370/904/323 suregrip
Rich 5150 69 is offline   Reply With Quote
Old 08-20-2013, 12:36 AM   #13
endlessearth
I didn't want to clear shoot it because from what I have seen doing that darkens the patina and makes the car super shiny. I also want my truck to continue to age gently. Lastly, I did it that way because I drive on dirt roads every day up and back from the ranch and it will be a lot easier to clean the dust off the wax using my California Car Duster.
Old 08-20-2013, 12:37 AM   #14
endlessearth
Thanks for the tip. I read that too.
Old 08-20-2013, 08:00 AM   #15
Clyde65
Clyde65's Avatar
That makes alot of sense endless.
Clyde65
Rebuild of Clyde
support our troops!
Old 08-20-2013, 08:34 AM   #16
gulfcoast66
64-66 CHEVY JUNKIE
gulfcoast66's Avatar
Truck Look really good!!! I'd put a Lil wax and drive it like that.. Good Job!!!
1966 C-10 Fleetside LWB, 350 Lt1 4l60-E
2008 Silverado Crew Cab, 4.8 4l60-E
1998 GMC Yukon 4x4 L-31 Vortec, 4l60-E
2017 GMC Serra 4x4 5.3 Vortec, 4l60-E
Do It In A Chevrolet
gulfcoast66 is offline   Reply With Quote
Old 08-20-2013, 09:43 AM   #17
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Looks really good !
I've been working the 'Burban as well ... slowly when time allows.
Originally white, then primered over. Scotch Brites and soap and water to remove primer ....
Hopefully will be all patina white soon.
Great job !!
I understand the work involved ...
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 08-20-2013, 10:39 AM   #18
endlessearth
Originally Posted by ChiefRocka View Post
Looks really good !
CLR on. CLR off. Baking Soda on. Baking Soda off. Wax on. Wax off. You feel like the karate kid after an especially hectic day. It is a labor of love for sure.
Old 08-20-2013, 10:40 AM   #19
joedoh
joedoh's Avatar
that looks great
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
