Old 08-12-2013, 12:27 AM   #1
Chevys10dr
Chevys10dr's Avatar
Just venting a bit
Well Arrrrrrrrrgggggggggg,
I think I just ruined a perfect rebuilt ZZ4 engine. Ready to do the break-in today, primed oil pump, setup timing to 10 degrees, primed the fuel bowl, and everything by the book, she didn't even try to start, after the 4th crank I get a high pitch squeal like metal on metal from the back of the block. Looks its back to the old engine that I took out because of burning alot of oil.
Chevys10dr is offline   Reply With Quote
Old 08-12-2013, 12:34 AM   #2
jons70
Re: Just venting a bit
Are you sure its starter not engaging the ring gear properly?
jons70 is offline   Reply With Quote
Old 08-12-2013, 12:37 AM   #3
jons70
If the solenoid is week, it might not engage the bendix drive properly or the bendix drive could be bad or the started isn't aligned properly
Old 08-12-2013, 01:24 AM   #4
Chevys10dr
Chevys10dr's Avatar
Thanks Jon, just checked all that, but everything looks on the starter side of things.
Old 08-12-2013, 01:29 AM   #5
Chevys10dr
Chevys10dr's Avatar
what's got me pissed is that the motor wouldn't even try to fire up there was on little backfire and that was it, it just keeps spitting fuel up in the air, I tried advancing and retarding and still getting the same results. AAAAAAAAAAHHHHHHHHHHHH
lol
Old 08-12-2013, 01:34 AM   #6
jons70
You must have the distributor out 180 degrees. Easy mistake and very common. Who put the motor together?
Old 08-12-2013, 01:41 AM   #7
Chevys10dr
Chevys10dr's Avatar
Short block was built by a pretty reputable builder in manitoba, flipping the dizzy 180 will be the next thing I will be checking tomorrow after work.
Old 08-12-2013, 01:56 AM   #8
jons70
I would try rotating the distributor 180 first. As for the squealing noise, I'm sure the starter is to blame, just looking won't tell you whats wrong. I'm assuming that it makes this squealing when you hit the starter right?
Old 08-12-2013, 02:07 AM   #9
Chevys10dr
Chevys10dr's Avatar
Thanks again Jon, After reading a few articles it is a good chance the dizzy is out 180, back at her tomorrow after work.
Old 08-12-2013, 02:16 AM   #10
jons70
Good luck with it and don't get discouraged, there's always a solution. Sometimes it's best to walk away for a while, ask for second opinions and the solution becomes clear
Keep us posted on your progress
Old 08-12-2013, 06:53 AM   #11
bobs409
1969 Custom 30 wrecker
bobs409's Avatar
Do you have a flywheel dust shield on? (particularly a manual trans but possibly an auto will do it too)
I had one that was rubbing the crank flange and made a hell of a metal squeel/screetch when I fired up my first 454. Scared the hell out of me.
Bob
63 Impala 283/PG/3.36 (under restoration)
66 Impala 327/PG/3.36
66 Chevelle SS 409/M22/3.55
69 Chevelle 307/PG/3.08 (future restoration)
69 C10 short stepside 454/TH350/3.73
69 Custom 30 tow truck 350/4 spd/4.10 (resto done, CRUISIN TIME!)
71 Cheyenne 20 fleetside 350/4 spd/4.10
71 Chevelle 6/PG/3.08
72 Chevelle 454/M21/4.10
bobs409 is offline   Reply With Quote
Old 08-12-2013, 07:01 AM   #12
TBONE1964
Cluster King
TBONE1964's Avatar
Originally Posted by jons70 View Post
good luck with it and don't get discouraged, there's always a solution. Sometimes it's best to walk away for a while, ask for second opinions and the solution becomes clear
keep us posted on your progress
^2
TBONE1964 is offline   Reply With Quote
Old 08-12-2013, 08:39 AM   #13
Tinkermc
Please let us know what you find it could help someone else at a later date
Tinkermc is offline   Reply With Quote
Old 08-12-2013, 09:29 AM   #14
slow-1
slow-1's Avatar
Me too on my 350 about a month ago...auto will definately make some disasterous sounding noises too.
I have also done the 180 out thing...it will spit and sputter just enough to give you hope, but it will never start that way...it will catch your Q-Jet on fire though.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
