Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-12-2013, 12:58 AM   #1
78c10 sleeper
12 bolt truck questions
Hi guys, im Geting ready to start building my 12 bolt truck rear end and I have a few questions, I know that a car and truck 12 bolt are a different animal but I know some things interchange. So my build goes like this aftermarket axles, c clip eliminators, spool and 456 gears and ill weld the housing to the tubes. I called stranged and they said that their spool interchanges between both the car and truck 12 bolt rear end and said I need to order gears for a series 4 carrier so im wondering should I get car gears or truck gears? I know u can put car gears in a truck rear end with the proper pinion bearing, but are the car and truck series 4 gears the same? Thanks for any info
78c10 sleeper is offline   Reply With Quote
Old 08-12-2013, 07:42 AM   #2
Hertzdaddy
Re: 12 bolt truck questions
Not sure on the gear selections but I've read that c-clip eliminators are not a great idea if you plan to drive many miles on the street. Its better to get the weld-on ends and the axles to go with them. But since you are getting a spool maybe you are building a race-only truck anyway.
Isn't the pinion diameter smaller on the truck gears?
Hertzdaddy is offline   Reply With Quote
Old 08-12-2013, 11:43 AM   #3
78c10 sleeper
Thanks for the reply .as far as the spool and c clip eliminators I've owned the truck for 5 years and has less then 1000 street miles on it and no rain driving due to the street slicks. The engine im building now should be around 700hp so I need Somthing strong.
Old 08-13-2013, 12:13 AM   #4
chevytruck1970
chevytruck1970's Avatar
Yes the pinion is smaller on the truck gears not interchangeable with car gears.
Justin
weight 3480 with driver
1.35 60ft
6.13@111mph 1/8 mile
9.80@131mph 1/4 mile
434 small block all motor
chevytruck1970 is offline   Reply With Quote
Old 08-13-2013, 12:21 AM   #5
78c10 sleeper
Well moser sells a pinion bearing /race to put the car gears in the truck rear. So witch would be stronger?
Old 08-13-2013, 01:04 AM   #6
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
The car pinion is thicker than the truck pinion.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 08-13-2013, 01:08 AM   #7
78c10 sleeper
I relize that but moser sells an adapter bearing so wouldn't the car pinion be stronger?
