Old 08-12-2013, 04:34 PM   #1
Ardee83
Ardee83's Avatar
American Eagle 211 Wheels
OK I need some help, I did a search but couldn't find the correct information I was needing. I would like to purchase a set of the American Eagle 211 series wheels in 17".
My 1st question can I run 17"x9.5" Front and Back? If so what does the backspacing need to be on each?
If I can't then what size would I need on the front with backspacing? I want to run the 17"x9.5" in the back regardless.
Truck info 83 SWB with 2.5" drop spindles in front and 4" drop leaf springs in back.
Thank you all!!
Ardee83 is offline   Reply With Quote
Old 08-13-2013, 12:32 PM   #2
Ardee83
Ardee83's Avatar
Re: American Eagle 211 Wheels
Bump...... I would like to place an order this week. Thanks
Old 08-13-2013, 12:38 PM   #3
77ChevySharkBite
77ChevySharkBite's Avatar
I can personally only answer 1 of the questions. You can run up to a 10" wide rim in the back. Now on the front, I'm not sure if you can run a 9.5" I would think you would run into rubbing/turning issues going that wide in the front, typically everyone sticks to an 8" wide for the front I know on my truck I have 8" wide rim.
Korwin
77 C10 Silverado Sharkbite LWB Build
67 Chevy C10 Frame Off
06 Dodge Magnum 2.7v6 aka swag wag!
2010 Honda Accord 2.4I4 DD aka Liquid Metal
77ChevySharkBite is offline   Reply With Quote
Old 08-13-2013, 09:34 PM   #4
Ardee83
Ardee83's Avatar
Thank you for your reply. I think I have it all figured out and will be placing an order tomorrow. Ryan
