Old 07-04-2003, 03:26 AM   #1
72gmcshorty
72gmcshorty's Avatar
No back up lights....
What cause no reverse lights to come on? My lights work when I press the brake pedal.
1992 Gmc 2wd
1972 Chevy Blazer 2wd
72gmcshorty is offline   Reply With Quote
Old 07-04-2003, 09:01 AM   #2
Gee_Emm
Sounds like grounding gremlins. Run a ground wire from a bare metal spot on the frame and touch it on the lense screw.
Gee_Emm is offline   Reply With Quote
Old 07-04-2003, 09:28 AM   #3
jay6891
Car Knocker
jay6891's Avatar
Might check wire and switch on top of column and see if you are getting power. Block your tires, turn on ignition,(not running),put into reverse and see if you got juice to lights.
68 c-10,91 sportside bed,350 .030 over,4 bolt,10-1 comp,2.05 intake/1.94 exhaust,1.6 Harland Sharp roller rockers,edelbrock rpm cam and intake w/750 carb, 700r4, 3.73 gears,Jacabbs Electronic Igntion w/Accel HEI distributer and super coil. ZR-1 roll pan, filled tailights. Blazer tank. Hidden hitch. 2 1/2" Flowmaster 40's. Parts bought but not installed>> ford 9" posi with disc. CCP front and rear lowering kit 4/5. Cab corners,foor boards,rockers, cab braces, Phatom grill, Painless wiring kit.
jay6891 is offline   Reply With Quote
Old 07-04-2003, 10:02 AM   #4
71GMC_3/4T
Weapons Of Construction
71GMC_3/4T's Avatar
Have someone stand behind the truck while you run the gear selector from park to neutral. If the lights blink on, the switch needs adjustment.
If you look at the switch, there will be four wires attached to it with two different plugs. The purple wires are for the neutral safety start. The other two wires are for the backup lights. Pull that connector off and short across the plug with a piece of wire with the key on. If the lights work, you have a bad or misadjusted switch.
Let us know what you find.
1971 GMC 2500, 402/TH400 4.10 Daily Driver
Lafayette, CO
71GMC_3/4T is offline   Reply With Quote
Old 07-04-2003, 12:23 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
All 3 of mine had kerfaggled switches on the column.
Old 07-04-2003, 07:56 PM   #6
71GMC_3/4T
71GMC_3/4T's Avatar
Glad mine isn't kerfaggled! I imagine that's pretty bad, eh?
Mine is slightly defuggered. It just needs a little adjustment, for the last 3 years...
I didn't think they even worked until one night I was backing up and didn't quite get in reverse. I was looking around trying to figure out who turned on the porch light when I finally realized my reverse lights were actually on! Now, if they would work when the truck is actually in reverse... I know, adjus tit! Some day I will dern it!
Lafayette, CO
Old 07-04-2003, 08:47 PM   #7
Boardrider52
Boardrider52's Avatar
i'v got that same problem
72' Jimmy
member of Above~n~beyond truck club
members.fortunecity.com/aboveandbeyondtrucks
Boardrider52 is offline   Reply With Quote
Old 07-04-2003, 11:17 PM   #8
Gee_Emm
I got the same problem too, I just wiggle the shifter if I want the lights to come on.
Old 07-05-2003, 04:27 AM   #9
68Custom
Hammer On!
68Custom's Avatar
Anyone out there NOT have this problem? I know its got my lights as well, oh well :p
Aaron
1968 C20
Inline 6 250
SM465 4 speed
1968 K10
Inline 6 250
SM465 4 speed
68Custom is offline   Reply With Quote
Old 07-05-2003, 11:19 AM   #10
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Since I have a panel there is no veiw out the sides and limited visibility out the back.I adjusted mine and while I was at it I added a back up alarm from a forklift.I feel safer backing up and it sure attracts attention.That makes it much more likely a small child won't wonder behind the truck while I'm backing up.Also makes it easier for other drivers to know they can have the spot I'm vacating if they will give me space to back out.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
