air bag valve won,t open?
I put a A.O.L. in the back,with electric selenoids {generic brands] but to air up it won,t do it, but can hear the air sol. out work.I forgot to put in a check valve for the rear.I took out the rear valves and bench tested and work fine.It seems like there is too much pressure for the valve to open.I have just a 2 selinoid for the rear,air into one valve with a tee going to the other valve for exhaust and bags.I hope someone can make sence of this,and tell me how to spell selanoid
Re: air bag valve won,t open?
is there a in and out for a valve,there are no markings?
AIRBAGPARTS.COM
The valves should have an arrow showing which way the air flows. Also, what pressure are you running? Most generic valves are only goo up to 120-150psi.
They didn,t like too much pressure,drained the system and it would open.Off to the store I go
