08-12-2013, 08:53 PM | #1 |
Vacuum line for brake booster
Hey guys I'm trying to figure out where my hose out of my brake booster needs to get vacuum from. I have a holley carb and a edelbrock manifold. Thank you very much
Posted via Mobile Device |
08-12-2013, 09:06 PM | #2 |
Re: Vacuum line for brake booster
On your Edelbrock manifold there should be a threaded port with a plug in it located between the back of the carbs base and the Distributor. That's were you'd typically get your vacuum for your booster and also use a "T" fitting to go to your vacuum modulator with a Turbo 350-400 trans if you have one.
68 GMC SWB Vortec 5.3 98 Chevy Blazer ZR2 94 Mazda Miata, LS2 6 speed, sold "No matter what happens, nobody gets out alive" |
08-12-2013, 09:10 PM | #3 |
Ok great so I can use that port I also heard of guys putting on a carb spacer and tapping a fitting for vacuum. I just wasn't sure of that thanks for the feedback
08-12-2013, 09:51 PM | #4 |
My Holley has a port in the back that feeds the brake booster. Could keep you from having to outfit with a fitting, etc..
