Old 08-12-2013, 10:41 PM   #1
1970conroy
65 K10 has no acceleration power/ throttle response
Recently picked up a 65 k10 step side. PO gave up working on it and got it for a good deal. First i got the correct b&m shifter linkage because he made some linkage but it was wayyyyyyy off from what it was supposed to be. Anyway got it to engage properly and took it for a drive. The truck has absolutely no power or throttle response, it will stop and go but doesnt seem to shift nor want to accelerate. Set timing @8 BTDC,new plugs, checked vacuum line/ vacuum(around 10) and just cant figure out whats wrong. Could it be the governor, modulator, blown rear end, bad tune in carb? Its got a mostly stock 350 with edelbrock 1406 carb and intake, with a th350 and 205 transfer case, will post some pics soon
Any help would be greatly appreciated
Thanks guys
1970conroy is offline   Reply With Quote
Old 08-12-2013, 11:27 PM   #2
1970conroy
Re: 65 K10 has no acceleration power/ throttle response
another pic
Old 08-13-2013, 01:11 PM   #3
MikeN
MikeN's Avatar
Choke not adjusted properly and not opening? Throttle linkage not opening all the way? If it's not the carb, it could be an internal engine problem. Probably need to check compression, etc.
MikeN is offline   Reply With Quote
Old 08-13-2013, 01:14 PM   #4
hopped up
hopped up's Avatar
damn im jealous. i wanna find me a k10 esp at a good price!! nice truck. id make sure the carb is all good. and chexk the vaccuum advance is working properly too. make sure the butterflys are ooening all the way. check all the simple things first
hopped up is offline   Reply With Quote
Old 08-13-2013, 01:39 PM   #5
jjzepplin
jjzepplin's Avatar
Also check mechanical advance under cap. Could be seized. And you have one of those finicky Edelbrock carbs that doesn't like any other fuel pump but an Edelbrock for some reason.
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 08-13-2013, 01:46 PM   #6
shok
I'd do all of the above, plus get a vac reading while driving it. New plugs etc. Does it sound like its running evenly or does it have an audible miss etc?
I keep hearing bad stuff about the Edel carbs lately. I've had a few Carter AFB carbs that were great and I think the Edel is just a copy. Is there some difference between the two that is introducing the finicky part?
1966 C10 250 with 3 on the tree Build Thread
Bunch of other cars no one cares about
shok is offline   Reply With Quote
Old 08-13-2013, 02:29 PM   #7
luvbowties
luvbowties's Avatar
Smile Re: 65 K10 has no acceleration power/ throttle response
If it idles good & has an hei dist, after testing for the obvious, try replacing the PICKUP-COIL--NOT the ignition coil-- in the dist. Just experienced a very similar situation & lucked onto its solution by trial-and-error and ruling out the obvious. I'd never heard of or experienced such before.
HTH,
Sam
luvbowties is offline   Reply With Quote
Old 08-13-2013, 08:15 PM   #8
Irishbleueyes
plug wires mixed up...
Irishbleueyes is offline   Reply With Quote
Old 08-13-2013, 09:01 PM   #9
tincan1966
tincan1966's Avatar
I just re read your first post- Unless you've got a HUGE camshaft, 10 in of vacuum at idle is not enough. Under acceleration, there would be even less. Should be 15+ inches of vacuum, and more like 18 to 20 even with a mild cam. Do you have power brakes/ If so, try pinching off the vacuum line to the booster and see if the reading increases.
At idle, does the vacuum gauge bounce or fluctuate a lot? That can indicate a possible bad cam or valves not seating properly.
Just a couple thoughts...
tincan1966 is offline   Reply With Quote
Old 08-13-2013, 10:08 PM   #10
jtrichard
whats the history on the engine? could be off one tooth on the cam????
jtrichard is offline   Reply With Quote
Old 08-13-2013, 11:08 PM   #11
62chevy302
hillbilly
62chevy302's Avatar
[quote/]The truck has absolutely no power or throttle response, it will stop and go but doesnt seem to shift nor want to accelerate.[/quote]
are the engine rpms going up when you mash the pedal? is it reving up? will it rev in neutral?
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 08-15-2013, 12:15 AM   #12
1970conroy
Just got back from a little vacation and was very pleased on all the replies, thanks guys! So first i did a compression test and all cylinders were in the 145-160 range so that was good. Installed new plugs, checked to see is vacuum advance was working properly and it was, throttle linkage was correct, and throttle was opening all the way, checked plug wires and order was correct. Played with idle screw and tuned the carb a little more, checked vacuum( 15 psi and steady)should it be better? and then reset timing to 12 btdc and started it up and it drove great, had good power and shifted smooth. Just finished doing the front brakes, new calipers, pads and getting rotors turned tomorrow, can't wait to have a driving truck again. Thanks for all the info again
Old 08-15-2013, 11:25 AM   #13
Irishbleueyes
15psi and steady is fine, so what do you think was the direct result of the problem?
Old 08-15-2013, 11:32 AM   #14
luvbowties
luvbowties's Avatar
...sounds like it had bad plugs, huh...
sam
Old 08-15-2013, 06:42 PM   #15
1970conroy
I think it was a combination of tuning the carb and then going back and playing with the timing, plugs added to it as well
Old 08-15-2013, 11:32 PM   #16
jjzepplin
jjzepplin's Avatar
Well it sounds like you got a good deal after all then. Congratulations!
