Tach face needs a redo.
My tach face has light rust. Is there a rescreener or decale available?
1955 GMC 250 8 Flatbed 1971 C30 157" 350 4spd 10' Flatbed 81 GMC K30 CnC 9' Flatbed 454 T400 89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958 71 LT1 Convertible, 72 Coupe 69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2 |
Member #1049
Re: Tach face needs a redo.
There are decals available but the ones I have seen the graduation markings are white in color instead of the faint green like the factory used,
Redline does re screening in the correct color, I have had dozens of gauges refinished by them over the year and always have been happy with the results. http://www.redlineg.com/redlineg/Welcome.html |
Moderator
![]() Join Date: May 2007
Can you post a picture of it?
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man |
Thanks Livrat, thats exactly what I need.
Leddzepp, I can not post a pic right now because my main computer is face down on the work bench. I will when I get it back together.
Old member
I contacted these people off E-bay. They said they could do the factory black decals if I wanted them.
![]() ![]() http://www.ebay.com/itm/380474492254...ht_2266wt_1112
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
pics
I've had the same issue and have contacted several gauge restorers. They do not have the art work to restore these due to the low volume. Right now you are Better off buying a reproduction gauge. I ended up with a cleaned up original face and VDO internals.
1972 C10 SWB, Air, PS, PB, 350/350THM. Second owner. 1965 Corvette roadster, 44K miles, 327/365 SHP, 4 speed, side exhaust, knockoffs, teak, second owner (bought in 1970), Have ALL numbers matching components. My frame off restoration thread: http://67-72chevytrucks.com/vboard/s...d.php?t=556703 |
Check with member theastronaut. He rebuilds and sells instrument panels for first gen trucks and may rebuild ours also. He has a thread on how he does it, here is the link to it...
http://67-72chevytrucks.com/vboard/s...01#post6164601 |
