Old 08-13-2013, 03:53 AM   #1
Nev68
Nev68's Avatar
SA 56 3100 build
Hi All,
I am a newby to this forum and to pickup trucks.
We have a 56 Chevy pickup
I am gradually converting the pickup from LH drive to RH drive. ( I know not everyone is in favour of conversions )
We can register LH drive cars / trucks here in South Australia but they must be as per factory (i.e. absolutely no modification at all!), as I want to modify our truck a bit we are converting to RH drive.
Plans are for EFI, Auto trans with O/D, A/Cond, aftermarket wheels. Nothing radical but the changes will make it ours.
Here's a few pix of our truck.
Dash & Steering converted
Jag front suspension fitted
Nev
Nev
Need a bigger garage so I can keep more cool cars alive
My build, a long way to go.
http://67-72chevytrucks.com/vboard/s...d.php?t=595909
Nev68 is offline   Reply With Quote
Old 08-13-2013, 05:32 AM   #2
Geri
Re: SA 56 3100 build
Nice Truck Nev!
Did you buy it in this condition or did you restored it from the ground up?
Geri
Geri is offline   Reply With Quote
Old 08-13-2013, 06:06 AM   #3
Nev68
Nev68's Avatar
Hi Geri,
We bought it like that.
We have a '68 Camaro (see pic below) that we built from the ground up a few years ago and I am not ready to a full build again ( not yet anyway )
Body on the pickup is good and solid, paint is a 10 footer.
Main focus for the 56 is make a nice driver with a few modern conveniences like EFI and AC.
Nev
Old 08-13-2013, 11:14 AM   #4
Kim57
Kim57's Avatar
Welcome.
Looks like a real nice truck.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 08-13-2013, 12:18 PM   #5
Daze57
Daze57's Avatar
very nice
Daze57 is offline   Reply With Quote
Old 08-13-2013, 12:47 PM   #6
_Ogre
_Ogre's Avatar
Looks good nev. How challenging is the rh conversion?
I've driven lh drive in rh country, it can get a little wild
shop air compressor timer
Old 08-13-2013, 09:13 PM   #7
apache200
apache200's Avatar
Nice looking truck!! rh conversion looks sweet!! do you have any closer pics of your door panels with the bowties in them? are they covered or all metal? Thanks
1958 Chevy Apache Stepside
1955 BBW Fleetside
apache200 is offline   Reply With Quote
Old 08-13-2013, 11:08 PM   #8
Nev68
Nev68's Avatar
I think the converison would be considered one of the easier ones.
My good friend has helped with the dash as my welding skills aren't good enough
Steel dash is a bonus though as we don't have to worry about padded urethane etc.
I drive the Camaro quite often (still LH drive) and you do get used to it.
The passenger seat is another story though.
Nev
Old 08-13-2013, 11:10 PM   #9
Nev68
Nev68's Avatar
Thanks, the door panels are covered in vinyl
Nev
Old 08-21-2013, 05:46 AM   #10
Nev68
Nev68's Avatar
Got most of the trans parts I ordered to rebuild the T700.
Now I have to sort a support so I can put the trans I the engine stand.
Nev
Old 08-21-2013, 03:15 PM   #11
_Ogre
_Ogre's Avatar
did the jag have rh steering?
that would make it an easy conversion
well easy as a jag suspension conversion
Old 08-21-2013, 11:23 PM   #12
Nev68
Nev68's Avatar
Yep, Aussie Jags are RH drive so we get all the good stuff by welding in the Jag IFS assembly.
Nev
Old 08-22-2013, 12:07 AM   #13
OrrieG
OrrieG's Avatar
For those that have one, the factory assembly manual has a section on the RH drive RPO that shows how it is accomplished.
OrrieG is offline   Reply With Quote
Old 08-22-2013, 11:02 AM   #14
_Ogre
_Ogre's Avatar
i looked and didn't find it. what section? not that i'd every need to work on one
Old 08-22-2013, 11:11 PM   #15
Nev68
Nev68's Avatar
You need to look very carefully.
There aren't large /obvious images of LH drive trucks.
I found the pages but they weren't much help to me.
Nev
Old 11-13-2013, 04:33 AM   #16
Nev68
Nev68's Avatar
Finally got around to fitting the lowered rear springs and fitting some hub caps.
Here's a before
....and after with caps
Nev
Old 11-13-2013, 11:28 AM   #17
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
Old 11-13-2013, 12:33 PM   #18
_Ogre
_Ogre's Avatar
shiney we like shiney
how is the front end fab coming out?
Old 11-13-2013, 03:53 PM   #19
meter swinger
meter swinger's Avatar
Looks awesome Nev68. Do you have any more pics of the jag ifs installed? I was curious if you notched the top of the frame rail to clear the upper rear control arm bushing? or notched the bottom of the frame rail and raised the entire jag unit?
Guess i need glasses.lol. Looked at the pic again, seems to be notched from the bottom. Neat idea.
meter swinger is offline   Reply With Quote
Old 11-14-2013, 02:02 AM   #20
Nev68
Nev68's Avatar
Thanks guys.
I hope it will be a little lower once we get the gas tank under the bed.
Unfortunately not much to report on the front end.
I've been busy on other stuff and since it is good weather here now we've also been out cruising in the Camaro.
Nev
Old 06-14-2014, 11:15 PM   #21
Nev68
Nev68's Avatar
Been a while since I've updated but home renovations have had priority and unfortunately I've just lost my job (33 years with the same company!) so my main priority now is to get another job
Anyway still hasn't stopped me getting wood
Just sanding for a nice finish
Putting on some stain
Just fitting the outside boards for the moment to support the bed on the chassis while I run new fuel lines and add a filler pipe
I've gone for a satin finsh on the timber instead of high gloss as there will be the odd bale of hay and other bits and pieces thrown in the back (occasionally)
Nev
Old 06-15-2014, 10:49 AM   #22
Kim57
Kim57's Avatar
Sorry for the job loss, good luck on the search.
Bed wood looks real nice.
Kim
My build thread
Old 06-15-2014, 03:50 PM   #23
bubba1955
Got a question on your Jag IFS conversion. Looks like you've done away with the original truck crossmember. Most Jag IFS swaps require a small notch in the top of the frame to clear the rear of the upper control arm. Did you pinch the frame narrower to clear?
bubba1955 is offline   Reply With Quote
Old 06-15-2014, 11:00 PM   #24
Nev68
Nev68's Avatar
No pinching of the rails, but we did have to play around with positioning to get clearance.
Nev
Old 06-15-2014, 11:01 PM   #25
Nev68
Nev68's Avatar
Kim
Thanks Kim
Nev
