Old 08-13-2013, 09:54 AM   #1
Hart_Rod
Hart_Rod's Avatar
Question Fuel rails question
I'm going to buy a set of fuel rails for my 6.2/Magnacharger and was wondering if anybody had any thoughts on the following fuel rails:
Aeromotive:
http://www.summitracing.com/parts/aei-14115
Holley:
http://www.summitracing.com/parts/hly-534-209
The Holley ones are a $100 cheaper and I really like the black, but I want to make sure they will not hinder the performance of the 6.2 with the Magnacharger. Thanks in advance.
Hart_Rod is offline   Reply With Quote
Old 08-13-2013, 10:29 AM   #2
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Fuel rails question
You linked to the same rails, for both web links.
What fuel supply line are you running to the rails?
I run those Aeromotives, with a -10 to the engine bay, where it splits to dual -8 lines into the back of the rails. Works well for me.
For the most part, fuel rails are fuel rails....they're pretty much all the same with the exception of the mounting provisions, and inlet/outlet size.
Also, what injectors are those? Are they stock length (really short) for the 6.2, or are they longer LS2 or LS1 style? That will determine which rails you get, since the mounting is different.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 08-13-2013, 11:03 AM   #3
Hart_Rod
Hart_Rod's Avatar
OOPPS!! Fixed it.
I am running a 10 AN supply to a y-block, with two - 8 AN lines to the back of the fuel rails, crossover and FPR (what's the part number for yours??) and then an 8 AN return (pretty much like your setup, ). Good question on the injectors. They came with the supercharger and are supposed to fit the stock rails of a 07 Denali. Here's a picture:
Old 08-13-2013, 11:35 AM   #4
Wasted Income
Boosted Member
I'm running the Aeromotive 13109 regulator, which is dual -6 in from the rails, single -6 out for the return.
Those Holley rails should work nice if you swap out the -6 fittings for -8 fittings, at least on the inlet side. The internal diameter of the rail is 1/2", which is the same size as a -8.
Turbo diesel
Old 08-13-2013, 11:46 AM   #5
Hart_Rod
Hart_Rod's Avatar
Thanks for the info! What Y block did you use? There seems to be a big variance in the prices for them. Is one better than the other? Also, what are your thoughts of this FPR over the one you are using? TIA
http://www.summitracing.com/parts/aei-13101
Old 08-13-2013, 11:58 AM   #6
Wasted Income
Boosted Member
Here is the fuel Y I used.
http://www.summitracing.com/parts/FRA-900611-RD
The regulator you posted should work fine. The fittings will probably be more expensive, to reduce down from -10 to -6 or -8, but other than that, it should work fine.
Turbo diesel
Old 08-13-2013, 12:09 PM   #7
Hart_Rod
Hart_Rod's Avatar
Thanks! I appreciate all the help.
Old 08-13-2013, 12:24 PM   #8
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
fwiw the injectors pictured appear to be the taller style EV1/EV6, not the typical MultecII shorty truck injectors.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-13-2013, 12:35 PM   #9
Hart_Rod
Hart_Rod's Avatar
Thanks!
Old 08-13-2013, 09:37 PM   #10
Hart_Rod
Hart_Rod's Avatar
I finally figured out what you were talking about here and I agree, your's is a better choice. I also found this one:
http://www.summitracing.com/parts/aei-13129
Looks like the only difference is the color. Thoughts? Also, what fitting did you use to connect the FPR to the fuel rail? Where is your boost reference line connected? Thanks....again.....
Old 08-14-2013, 10:47 AM   #11
Wasted Income
Boosted Member
That regulator says that it only has one inlet...you need two in order to use the regulator to tee the rail outlets together.
I used this fitting to connect my regulator directly to the outlet of the Driver Side fuel rail. You may or may not have that option depending on blower clearance.
http://www.summitracing.com/parts/aei-15681
Turbo diesel
Old 08-14-2013, 04:00 PM   #12
Hart_Rod
Hart_Rod's Avatar
Thank you sir!
Old 08-14-2013, 06:17 PM   #13
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Hart, get this thing on the road. I need you to convince me that those top mount blowers do more than just heat the air up
Old 08-14-2013, 06:36 PM   #14
Hart_Rod
Hart_Rod's Avatar
Roger that! I'm doing my best. I'm just waiting on my wiring harness and then will need to tie up a few loose ends....
Old 08-15-2013, 02:11 PM   #15
Hart_Rod
Hart_Rod's Avatar
OK, so I got the Holley fuels rails (they are really nice!) but they won't work with the injectors that I have. I need some EV6 injectors that are about 1/2-5/8" taller...... Any suggestions?
EDIT: I wonder if these will work?? http://www.summitracing.com/parts/tfs-89960
Old 08-15-2013, 02:51 PM   #16
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I'm confused, the pink injectors didn't look like the Multec's that I had on the truck before switching, they were much fatter....but you say they are shorter than the ev6?
FIC injectors would often be my choice if going aftermarket.
Old 08-15-2013, 03:29 PM   #17
68GMCCustom
Truck and auto performance nut
68GMCCustom's Avatar
thats a big added cost. can you just mount the rails lower by modifying the mounting points height or something?
Kurt -
'68 GMC short step - NIB '09 LY6 6.0L crate motor w/mods, NIB '12 crate 4L85e w/billet 3k stall Circle D, 3.73 posi 12 bolt, DynaTech f-swap headers, 3/4 drop, handling mods, etc. - my toy
'72 Chevy LWB C-10 Highlander - 350/350 ps/pb/tilt/ac - not original but close
'06 Chevy TrailBlazerSS - LS2/4L70e - little black hot rod SUV - my DD
'18 Kia Sorento - wife's econo-driver
'95 Chevy S10 - reg cab shortbed, LS, 4.3, auto...
my '68's powertrain and chassis build -links broken
A surprise phase - carb to efi -links broken
68GMCCustom is offline   Reply With Quote
Old 08-15-2013, 03:48 PM   #18
Hart_Rod
Hart_Rod's Avatar
They are bosch injectors. What are FICs?
There isn't enough room to go lower because of the s/c intake. Whats a little more $$$.... plus these were only 41 lb injectors...probably not enough for the cam and s/c...
Old 08-15-2013, 05:05 PM   #19
Wasted Income
Boosted Member
60s are the bare minimum for that setup. Do you ever plan to run E85? If so, step up to a set of 80s.
http://www.racetronix.biz/itemdesc.a...114992&eq=&Tp=
Turbo diesel
Old 08-15-2013, 05:28 PM   #20
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
FIC is Fuel Injector Connection, and I've dealt with them before when finding flowed injectors for imports used to be hard.
Example, here are some Siemens 60lb's for 399.99
http://fuelinjectorconnection.com/sh...p?productid=20
on the same page they have 72lb's for the same price. Plus they are flow matched.
Those racetronix don't look bad tho either Wasted.
Old 08-15-2013, 06:39 PM   #21
Hart_Rod
Hart_Rod's Avatar
I won't be running E85.... Do they not offer these in the USCAR connector? Do you think those injectors will be tall enough? Here are the specs (in metric @#%^&)...
http://www.racetronix.com/images/injectors/L107.pdf
I had to move the FPR to the passengers side and to the rear. So I'll be running both supply lines up the front. That actually works a little better with the way my lines were laid out before. Did you use a 6 AN line to connect the one side to the FPR or did you stick with 8 AN like the rear?
Old 08-17-2013, 10:26 PM   #22
Hart_Rod
Hart_Rod's Avatar
Any thoughts on the injectors?
Old 08-17-2013, 10:43 PM   #23
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
60's min, 72-80 will give you room, 120's if we put it on corn juice and spray it
Old 08-20-2013, 12:20 PM   #24
Hart_Rod
Hart_Rod's Avatar
I'm thinking about going with these, so please chime in if you think I'm making a mistake, .
http://fuelinjectorconnection.com/sh...?productid=522
Old 08-20-2013, 01:16 PM   #25
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Look good to me. The Siemens injectors are totally proven across platforms, and if they are willing to include the correct wiring connectors for the same price thats even better.
